Electro scrap magnet
I'm going to use some duct tape and welding cables (y) πŸ”₯
I think your installation will look like this
but with an isolator between the batteries πŸ˜‚πŸ˜‚πŸ˜‚πŸ˜‚
Rob65
Just going to the batteries on the machine if the machine is running it should keep up with demand
as for switches been thinking about it todayπŸ€”
going to use a couple of 3 phase contactors (switches) and wire up as if I’m wiring up a motor for forward and reverse but on one contactor will be latched by a relay and the other momentarily so it reverses the polarity momentarily, using two buttons on the joy stick one will enigise the magnet the other will cut the power to the first contactor and also switch on the second one (only while the button is pressed) to release simplesπŸ‘
Mog, Sounds about how the pro built systems work.
