Help please Fuse popping
Deanofire
so your saying replace the large black relay and the 4 little blue relay's but dont replace the latching fuse just test it ?
could there not be an intermittant fault with the latching relay ?
the black relay is the latching relay BTLs
the blues, if the same as the one in the pic, are as per your link above
need to see the pins on this one
and this one
and this looks to be conventional SPDT (single pole, double throw)
There is another version that looks exactly the same as this too.
It's SPST (single pole, single throw), but with two common output terminals (S6 & S8 below)
You can tell them apart as the SPST type has two (87) output pins
the SPDT type has output pins 87 & 87a
Taken from Hallas catalogue
:cool: .. never seen one with two 87,s :oops::unsure: .... good shout Gecko .... pin numbers essential then
Deanofire
and this one
Ok mate thanks as soon as it stops raining i will get out there and take pictures again of both the black ones , from memory i think the first one (hella one) only had 3 pins, but i will confirm
Deanofire
three pins !!? :unsure::unsure:
Deanofire
Deanofire
believe it or not we have rain today ( back to 25 degrees and sun tommorow) but as soon as there is a break i will get out there and grab the relays
and No. 2
Are we talking 87 and 87a? Or two actual 87s!
Was looking at this one
Deanofire
It isn't the ignition on buzzer is it?
it does have an ignition buzzer sound and i havnt been able to find an actual buzzer unit so that sounds legit i will tryan get out to test it but it only buzzez when the 40A fuse hasnt blown
Deanofire
Two 87’s , clearly shown in the diagrams above. Can’t say I’ve ever seen one or knew one existed! I can’t really see the point in it, must be such a specialist item? And just because there’s a drawing of it doesn’t mean you could get one from anywhere!
un the relay it shows 87 and 87a (center pin)
