Help please Fuse popping
Deanofire
My gut feeling is you’ve got a wire rubbed through and shorting to earth somewhere. But you first need to rule out all components that could also mimic this fault.
Have you traced the feed wire to the glow plugs back to a relay?
Hi
That is what i suspect as well. we tried tracing the wire yesterday but it showed on multiple connections on the relay.
This may help with some of it!
From battery live it looks like it feeds the starter main, back to ignition switch, 40 amps would be a larger circuit ie starting, charging, heat, light circuit, servo solenoids!
Deanofire
The wiring diagram is not that good, it’s not very readable!
i think i have worked out the fuse wires that are blowing.
no. 2 is servo control and instruments 40A (although my diagram shows a 60Amp fuse
no.3 says wipers 15A (but i have an open cab and no wipers so i dont know whats on that)
I tried getting the little switch that isolates the hydraulics out and disconnected that as i thought maybe with exposure to the rain it rusted and although it looked dirty when i tried it still blew the 2 fuses.
although when i disconnected all the instrument panel plugs only the 40a blew and not the !5a.
Do you think it could be one of the relays ?
I do not know how to test relays but i do have a meter
TIA
Deanofire
yet on that diagram it shows the servo one as only 5A and that is the one popping with 40A in it and the one next to it with 15A is wipers which i dont have
But it is definitely one of those two wires as the main live on the back feeds those two that pop and the 3 one that looks like a fan but that fuse is fine.
The two wires that go to the blowing fuse are numbered 101 and 107
Deanofire
TIA
The little switch should be only an earth that would excite a relay that in turn would feed the pilot solenoid, (relays) if they are 4 pin, you will have a fused live feed, a switched live, or a switched earth, the fourth wire will be the supply to the item!
OK latest update on the fun and games.
today i disconnected the top little fuel pump and the tank fuel lifter.
Turned the key to position one again and...............blew the 40A fuse yet again. i am really out of ideas now !!!!
disconnected electrically presumably or just the fuel lines?
Deanofire
i am trying to trace back the 2 little wires from those positions that are blowing the fuses but as i said i cant find them on my wiring diagram . yellow 101 and 117
Diggerdavey
Does the fuse blow when it’s put in or when ignition turned on?
Instead of wasting loads of fuses wire a bulb across the fuse terminals. Bulb will light whilst there is a short to earth and go out when you disconnect the source of the short. Disconnect anything passing through that fuse one at a time to eliminate. If nothing extinguishes the light it’s time for a wiggle test on all areas of wiring harness you can get to. Possible wire shorted to earth.
