's called getting old Rory and having yer HD over full .... as I've said before I reckon I have now forgotten more than I currently knowIt's called senility
Druid,'s called getting old Rory and having yer HD over full .... as I've said before I reckon I have now forgotten more than I currently know![]()
Well we aren't off to a great start today. First call to PES Plant reveals:
Workshop manual,
Steering and skip ram seal kits
Lockheed Master brake cylinder (or seal kit)
are all NLA as far as they are concerned.
Overhaul kits for 85M gearboxes (which I have) are available, the other type are not.
I have other leads to follow up on those so it's not over yet.
Does anyone know how to get the skip ram off? It looks like a simple through bolt with grease nipple (missing), but is not so simple afterall.
One side looks like this and you would expect to undo the nut and bash it through, but it's solid:
The other side however has started to come out by driving a steel wedge in.
The odd thing is the other threaded side is not moving. You would expect it to pull it through in one piece, but it isn't...
Drives out from the nut side to the flanf side.... So as per last photoSadly it's not so simple, there is more to it than that.
It's definitely coming out:
And this definitely won't go in as it's got a shoulder on it:
So what does the nut do? You would expect tightening the nut to pull it out which can't be right.
Will just be seized plenty of heat (even from a plumbers blow touch will help) and a heavy hammer
the washer is bigger than the pin to stop it pulling back through when the nut is done up ... cut 'em both off flush and as said cut either side of the rod eye .... you then only have the pin lengths in the bosses to contend with and if the flange end IS moving then you can belt that into the void left by the removal of the rod end. Can then also get a drift in and at the nut side .. again as said, if all else fails slit the plate and boss to open it up and release its grip.Sadly it's not so simple, there is more to it than that.
cut off flush to lugs
and ..
tapped out with a 1lb hammer after it was slit Thanksthe washer is bigger than the pin to stop it pulling back through when the nut is done up ... cut 'em both off flush and as said cut either side of the rod eye .... you then only have the pin lengths in the bosses to contend with and if the flange end IS moving then you can belt that into the void left by the removal of the rod end. Can then also get a drift in and at the nut side .. again as said, if all else fails slit the plate and boss to open it up and release its grip.
was the only way this was coming out ... had good access to belt it/jack it out .. would NOT move
View attachment 33402 View attachment 33403 cut off flush to lugs View attachment 33404 View attachment 33408
slit the bosses View attachment 33405 and ..View attachment 33406 tapped out with a 1lb hammer after it was slit![]()
You've gone too far now but when i did the steering ram seals and the 2 swivel ram seals on my old 6 tonne thwaites I didn't fight on taking the rams completely off. I only removed whichever end was easiest so i could get the ram into 2 pieces to change the seals. Admittedly it only needed seals and the right one were easily obtained. Its slightly different if you need to take the ram off to take it somewhere to be sorted or even to measure for seals.ThanksI see what you mean now, will treat that as a last resort. I note you said jack, I did realise this aft I could get a bottle jack in there and try that.
If I had one![]()
To recondition the BMC, new seals as per what fluid I want to use and a SS liner. £85 + VAT and shipping.Classic Car Brakes Ltd, brake cylinder re-sleeving, brake servos, brake calipers, Classic car spares, classic car brake parts, hydraulic brake components, classic vehicles, vintage vehicles, classic cars, Stourport, Stourport-on-Severn, Worcestershir
Classic Car Brakes Ltd carry out brake cylinder re-sleeving and are specialist suppliers of hydraulic brake components for classic and vintage vehicles such as classic cars, vans, trucks, buses, plant and agriculturewww.classiccar-brakes.co.uk
