Buying and renovating a Benford TT3000 dumper
I can only try unscrewing it by gently tapping or turning on the banjo boss and see if it comes off that way.View attachment 33352
I wouldn’t advise tapping on the banjo to unscrew it, I’d be afraid you will simply break it off.
A big set of stilsons would be my first choice to unscrew the cap.
:ROFLMAO::ROFLMAO: selfish ****ers always turn up when yer's busy :ROFLMAO:
Only kidding Doob .. was nice to see you both, as always ... welcome here anytime Boyo :giggle:(y)(y) ..... don't leave it so long next time :):)
I’ve got it down to a fine knack of turning up just as the jobs nearly done 😉
For a start off give a proper clean so you can see exactly what you're dealing with.
and get it off onto the bench so you can get at it tidy
L
LKSF
Pennine Hillbilly
It's something to do with that:
It's like a big clip shaped a bit like a staple, I don't know whether to push it in or pull it out, but think it's holding the cap on.
I think you're supposed to press it in somehow and push the end cap off.
Looks like what jcb used to use on some rams. If it is that clip has a tight 90 on one end which hooks into the cap and there's a groove in both the cap and the cylinder. Cap pushes in and then turns taking the clip in through that slot and that's what retains the cap. In theory you should be able to turn the end cap and feed the wire clip out and then pull the cap out.
L
LKSF
Pennine Hillbilly
The cap turns the whole way round, but won't come off. One end of the clip will come out, but it doesn't feel right, hope I haven't broken it!
The hole is for a C shaped pin spanner. You turn the cap and unwind the locking wire as @GazCro describes.
Sounds like the other end of the locking wire has broken off. Retrieval of the locking wire will be awkward now but not impossible. You need to get hold of the bit you can see and now pull it out of the groove it’s in.
It does look as if the bit of the clip you can see is the 90 bend. Might be worth keeping it in place as it might help push the rest of the clip out
L
LKSF
Pennine Hillbilly
Having a bit of a Google whilst getting some lunch, V8 Druid hang your head in shame!
L
LKSF
Pennine Hillbilly
And there we have it, the money shot:
I'll leave these here so they can help someone else perhaps:
In either end is a
GE25ES-2RS Spherical Plain Bearing​
Which are a few quid from a bearing shop.
The pin which goes through them is worn so needs turning down until a piece of thinwall 25mm tube can be pressed on, then back into the lathe to finish it to 25mm then it's back to size and all the steering ram slop will be gone.
Thanks all for your help with that (y)
Sometimes handy in situ if you need pipe and stilsons on it though
know what you mean, but i usually clamp 'em to the bench, but i'm lucky in having an extremely bloody heavy bench to do it with
bloody hell man that's 3 years ago .... got a job to tell you what i was doing 3 days ago :rolleyes:
make a new pin? :rolleyes::unsure:
Looks like we all on the case with this one! The ram looks like it is joined probably threaded just to the left of the number 4🤔
