Gearbox work
Unfortunately got a crunchy 2nd gear on iveco 7.5t - might get it repaired before selling .... and recommendations for exchange unit etc
Cheers
Aha but french will want 3k knocked off because everything is a fortune here whereas I might get it done much cheaper ... so I wanted a ballpark to negotiate with 👍
Cheers
do you double de-clutch up and down ?
What box is in your wagon..... Might of brought a Iveco to make a tractor trailer out of ;)
Depending on the type of crunch check the gear linkage cables
When they stretch or wear it can sometimes cause a bit of a crunch
Nope .... should I ? thought that went out with the Albions
ALWAYS makes for a smoother drive and change ....... unless it's an auto :LOL: ..... you can make a crash box drive like a synchro doing it .... never drive a manual of any description any other way
Really ..... you just enjoy the experience...big wheelin 🙂
I did have a quick butchers .... what a dog's dinner of a setup, 2nd and now very occassion 4th will do it, so that could possibly related to something been badly adjusted.
The daf setup is much better scania not to bad but every cable controlled lorry I've driven was unnecessarily hard work( I only drive well used lorry's so don't know what they are like new)
Yes its certainly never been that good .... never grating but there is a certain knack to it, next time it's pissing down I will have a good look and see if 2nd and 4th are related 👍
Highly likely as they will both be utilising the same cable in the same direction for 2nd and 4th
Routy56
Routy56
That’ll be the way that your dad taught you 🥰
