Hilti
Am I the only one who just uses Silverline sockets ad never has a problem?
Cyberprog
Cyberprog
Weighing in my 2p's worth here - I bought a load of 10.8V Li-Ion Bosch gear about 10 years ago and it's still going strong. I've also got the 36V Li-Ion SDS as well (similar age) and that's unstoppable. Apart from when I dropped it off a ladder. But we won't talk about that.
I dropped my ten year old Makita impact driver from a barn roof onto concrete and it didn't die..
Cyberprog
Cyberprog
This was the SDS, dropped it from about 3m onto a concrete floor and smashed the case - but it's quite a hefty beast and I wasn't surprised I'd bbroke it.
The 10.8 I've dropped loads and it keeps on chooching.
just ordered a Makita DTW1001 for work, its a 3/4" impact wrench. seems to have good reviews so will see how it performs when she arrives :geek:
Let's hope it's as good as Makita stuff usually is .... for nigh on 400 quid :oops:
As mentioned earlier in the thread, the motor in mine died within six months. However, Makita collected it in the morning and dropped it back repaired the next day! f**k knows, how, probably black magic. Good service all the same.
Druid, I think they're more like £250 as a bare tool.
yes but no bloody good to man nor beast without some batteries to fit it!
£390 inc. two batteries, charger and case ;)
Yes, but everyone who already has makita already has batteries..and I've gone on enough about how I only use knockoff batteries anyhow!
£250 isn't expensive for the time it saves me, and I only use it once a week or so if that.
but what's the cost of two knock offs and a charger Ruben :unsure: ... if you ain't got batteries already it's 390 quid.... end of :rolleyes:
Not knocking it ... had a 'new' Erbauer battery drill from screwfix last year and it's bloody brilliant (y) ...
as has been said elsewhere, battery tech has come on so far, they're a far cry from battery drills of ten years ago.;)
I have two Makitas which're going on that age, perhaps more .. good drills, but the batteries let them down.:(
The new one just goes and goes, 'til it stops - then change the battery ...
the old ones just get progressively slower/weaker 'til flat and change.
Would love to be able to get some new batteries of the same ilk for the old drills, which're still like new ... the one has hardly ever been used :rolleyes:
in the right application ... i.e. nut running day in day out, I can see just why one'd invest 400 quid in that .... got a corded Makita impact and plenty of air driven ones up 1" drive ... get 'em out when I need to ;)(y)
Grahams
Grahams
I've seen places doing the cells which you can fit in the old battery casings. Normally need a bit of soldering, but I expect you could cope with that.
Graham
Graham
well that'd be a handy solution Gra (y)
It’s an animal, make no mistake!
We've been using metabo impact guns in half inch but someone recently had a malwalkie gun and seemed good, a few tinternet searches seemed to bring up makita as being the one to go for.
Stick a 5ah battery on it and hold on tight! :)
G
Gez_lewis
Cracking tool, as said 5 ah Batterys and there's not much it won't undo.
It doesn't like crap sockets tho. Get a good 3/4 -1/2 impact reducer aswell , bloody handy
