Bloody hell .... how many leaks did you have![]()
100% by the sound of it.....
OMGThis describes it very accurately.... The only bit that didn't leak was the bucket. Most have been fixed either by tightening hose connections or new seals but one persists in the tilt ram valve block which has had all its seals replaced on Saturday so there's something it doesn't like. .....
On a positive note it seemed to fly today, really getting into controlling tilt, rotate and bucket crowd at the same time. SO glad I went for the full DC2 system. I know I was an advocate of the simpler button and pedal system before but if you are reading this thinking should I save up for the proper control system then I cant recommend it enough, so many jobs require simultaneous tilting and rotating to get in one pass and you wont regret it.
Firstly, I’m sorry that Ollie has had issues with his Engcon.This describes it very accurately.... The only bit that didn't leak was the bucket. Most have been fixed either by tightening hose connections or new seals but one persists in the tilt ram valve block which has had all its seals replaced on Saturday so there's something it doesn't like.
The replacement tilty should fix all this (or give me all the leaks back again) but during a conversation with Rory yesterday I realised that after the original 2 day fitting time (which is fair enough, its an investment into my future business) It has cost me a day in downtime so far. Not Engcon's fault I'm so busy and working all the weekends but its got some time saving to make up for that. I'd imagine the fitting of the new one will no doubt take a good couple of hours and rightly so - its got to be right from the start but its not ideal when you are on day rate to a builder who at the end of the day just wants his job done.
FYI the JCB 8026 has been down for 5 days in its 4 year lifetime and 4 of those were within the first year. Teething problems are not unusual and Engcon have and are doing all they can to sort it but just like my beloved JCB, 80% of the issues could of been avoided in the factory and service engineers are expensive to keep sending out - not good for their or my business. I should mention that Shaun Gratton is working hard behind the scenes on this and has been in touch a few times to see how I'm getting on and is taking up my issues direct with Engcon on quality control etc.
That was a small one mate! The job was overlooking a marina, hence why I hauled the waste away rather than burn on site.looking at the size of their boat parked up, i think you were a bit cheap mate!
Very much Scandi philosophy, DoobinI don't often use my tilt hitch, but when I do it always puts a smile on my face and can make some serious money. Although I have no tilt rotator, I've invested a lot in other specialised attachments and yesterday I used most of them. I used the grab to remove a Leylandii hedge and load it straight onto the tipper truck.
Well you started it by saying your tilting hitch brought a smile to your face^What's with all this Hygge mate? My missus was reading a book that was supposed to be it recently. I flicked through and as far as i could tell it was just your standard modern chick lit crap. All about some bird trying to 'find herself' as usual.![]()
That's not bad Doobin, I was looking at your pics thinking you got some serious work done in a day there. With the fencing I'd of guessed it was 2 days work but obviously things worked out and you smashed it out in one day. I certainly wouldn't call it expensive, you are a professional with the correct tools, turn up and do the agreed job plus some by the sounds of it. You make good money doing it and the client is happy, why take more days to do it to satisfy a perceived "value for money" by the customer when you can do it in 1 and earn - you price it, you take the risk and you win... sometimes.Two men and a digger for the day. Left the yard at at nine (didn't get confirmation until the evening before so had to load in the morning) and were back by six. £1512+VAT.
That’s the thing about tiltrotators. You expect it to be good, but after a bit of practice it exceeds your expectations. Wish every thing was like that.Todays tilt rotator discovery is I can pick up bulk bags with the tilty still on the machine. This is a right result as its something I do a lot and I thought I would have to drop the tilty off but no need - the good old 8026 has my back. Seriously I haven't found something I cant do with it yet, all the perceived compromises I thought I would have to make haven't come true and its putting a smile on my face everyday.
Just a more general note here: The gripper range only starts on the EC204 and adds around 50kgs to the weight of the tilty (which is around 116kgs without it). So firstly you need a 2.5 - 4t machine. I've also noticed that with some machines at the lower end of this scale when you have a tilty, gripper, grading bucket and a load of wet muck, they are getting a little noddy. I'm pretty sure I had this conversation with Ollie but I have certainly had it with a lot of other owner-ops. Going for the smaller SK02 grab (which costs around the same as a gripper) is, in some cases, a better option in that you can drop the bucket off and put the grab on and do what you need rather than have the extra weight on all the time.Just to follow up on what Robert has said.
Firstly I am not the Shaun in Leek, I am just down the road from Engcon in Tewkesbury. I have the basic set up SS15 on my Kubota and it can tilt and rotate at the same time. What I do find when grading is the machine is not anywhere near full revs, so although the oil flow to the tilt and rotate is the same it is still quite a smooth action when you are operating. I am looking forward to seeing Ollie in action shortly to gain an opinion on what way to go when I upgrade next. I think Ollie has the gripper and grab which I think would be a another good reason to step up too when the time comes.
" Pronounced "hoo-ga," this Danish concept cannot be translated to one single word but encompasses a feeling of cozy contentment and well-being through enjoying the simple things in life "^What's with all this Hygge mate? My missus was reading a book that was supposed to be it recently. I flicked through and as far as i could tell it was just your standard modern chick lit crap. All about some bird trying to 'find herself' as usual.![]()
Is that what they used to shout in gladiators on a Saturday night in the 90s" Pronounced "hoo-ga," this Danish concept cannot be translated to one single word but encompasses a feeling of cozy contentment and well-being through enjoying the simple things in life "![]()
I presume that your size tilty doesn't have a rotary coupling through it Shaun, so no oil flow to enable a gripper/grab/hyd hitch?Just to follow up on what Robert has said.
you actually used to watch Gladiators, Mog?Is that what they used to shout in gladiators on a Saturday night in the 90s![]()
you actually used to watch Gladiators, Mog?![]()
