H
Howdeedoodee
Hi
It was a crap day raing all day here in Nottingham on Monday so I didn't get chance to take some more detailed short video clips and photo's.
I'm doing an extension digout tomorrow all day and it'll be a long 12 hour day.
So I'll do the video & photo's on Thursday.
I'll also do a few detailed sketches of the ignition switch indicating what connectors have 12volts at run & crank positions.
I did quickly have a look this evening in the dark with a torch to see where the start/stop solinoid was.
I found it so I unclipped the plug and gave all the pins a thorough clean and WD40.
The wires to it looked OK.
To add to the ignition sketch I'll also do sketches of things like alternator voltages, stop/start solenoid voltages, anti start module pins and whatever else i find when I'm at run and crank positions.
One thing that came to mind is that even though the ignition switch was perfectly clean inside I wonder if the copper tabs inside are worn and something isn't getting 12 volts.
Once I've done all the sketches with voltage details on I'm praying someone can point me as to whats wrong because I've god a dig out on Saturday that I've cancelled already and need the dumper for it.
Speak soon.
Thanks for all the help and pointers so far.
John
Speak soon.
John
