Hi
In neutral both the lights are off.
In reverse both the lights are on
In forward only 1 light is on
No lights change on the controller when the key is turned to start.
The only light that is ever on is light number 3.
I've had the dumper 5 weeks or more and only the oil light has ever iluminated when turning the key, it then goes off when the engine is started.
Mk
Maybe the led's are faulty?
Yeah something is a miss then, either a faulty control unit or a wire to it. When the joystick hits neutral it should switch a light on the controller can you check the Orange wire into the Anti-start module, see if it changes between 0v and 12v when the shuttle lever is moved.
Then check the White and Purple (Seat switch) this should be 12V as you have bridged the wires.
Next the Orange and Yellow (Emergency stop) this too should be 12V.
Next when the key is turned to start (crank) position 12V on red wire at the module.
Next check that the White wire to Anti-start module has 12v with key in first position i.e. ignition on.
Next check Brown/White wire it should be 12V all the time.
Finally check Black wire is actually ground i.e. check between it and a known 12V source and verify the unit is getting a 0v reference.
The LED's rarely fail, like I said earlier it looks like the oil pressure LED has been fed from an alternate location and that the others have been left disconnected with the idea they are less critical lights. The green/yellow should have 12V feed from key on, my bet is that it doesn't due to either a blown or missing diode. But I can't see the dash wiring in enough detail to confirm my suspicions.
