Not had a chance to use my 8026 yet, which is still sat on the trailer waiting for a fitter, turns out when it left the factory someone couldn't be arsed to sort out the belly plate pan so there is currently two bolts missing on one side which the welded nuts are cross threaded as the protection plate sits over the holes just enough to stop the bolts going in square and a third on the other side was half way in.
Which I only discovered as was hydraulic oil on the trailer bed, which I'm assuming is residual from when the hitch pipework was done, which no one also bothered to check the sight gauge as its empty.
Plus on top of that there is also the odd spot of surface rust on bits
