What post knocker for a 1.8t mini
Dr pecker
Dr pecker
So you mean the chisel bit or the whole thing ?
I’ve got a wee cat breaker I use on the machine at the moment could I put a side cradle on it and a knocker chisel ?
Cheers
Vin
Yes, we sell the complete unit but can also sell just the knocker cups for any breaker.
That’s my breaker , it says cat on it but I’m assuming it’s made by someone else . Any idea what it is ?
that'll be a tough one to side mount :unsure:
First thoughts looking at the photo, a plate sandwiched between the top mount and breaker turning 90 degrees down, with a low mount on, then a saddle against the breaker body at the bottom and a clamp around it.
The "silenced" breakers are already heavier thanks to the cast jacket they are in. Tbh if you want one with a breaker cup on imho you'd be better off starting with a steel framed hammer to begin with.
did wonder why they were in such a substantial cast jacket .... know sweet FA 'bout 'em
Does make a big difference to noise levels especially on smaller breakers although it also spoils smaller breakers for small spaces like trenches.
Does mine have a cast jacket ?
looks like it ... all organic looking smooth lines wrapped round the guts ...... but I know sod all about these things other than they go dat dat dat dat when they'm working ok :ROFLMAO::ROFLMAO:
This is what I use on my 1.8t machine. A chap was making them for compact tractors so I asked him to modify one. It’s pretty good really- quite heavy at full reach (which it you have to reach a big to get on top of a 8ft strainer) 130kg hammer weight.
how do you release your hitch with it on?
There’s a guy trying to sell this on fencing group, sadly he’s up near duneray right on the northern tip of Scotland. Be an upgrade on the p180 on 5 tonner
I had one of those on my 5 tonner (kx161) for a while. Had a 250kg weight. Hardly even noticed it.
