What's with the big lads all running big tracs and low loaders on their sites? Mannery and flurphy etc...all on white with onlicenses? Or exempt?
no issue ON SITEWhat's with the big lads all running big tracs and low loaders on their sites? Mannery and flurphy etc...all on white with onlicenses? Or exempt?
A lot of bypass/road jobs will incorporate existing roads as the worksite.....no issue ON SITE
Sactly on the roads all time on jobs round here.A lot of bypass/road jobs will incorporate existing roads as the worksite.....All very odd
Ease up Graham still a bit of fight left in meage does that to you...... it's deciding when to pull the plug --- if you don't get it decided for you
ditto Kev .... til Aug. 22nd, 2010 ...... never know what's around the cornerEase up Graham still a bit of fight left in me![]()
I did ... but'd been considering a 'wind down' for some time - had stuff still to do, just bought a new house, and BANG! all changed overnight, as good asYeah depends if its something you love or a means to an end.
if it's live to traffic they have to comply with reg.s - end of ......A lot of bypass/road jobs will incorporate existing roads as the worksite.....All very odd
semi correct ... running 2/3rds - 1mile and in live traffic .... fact remains they got hammered for it ... and rightly so - haul rd was in the spec. ... they were cutting cornersDepends. Some jobs will take full possession of set roads.... Often only bypass jobs. Road will still be open but it's management entirely at the whim of the project.
I know the road your on about, my understanding is it was due to distances involved and the fact the entire road was not in possession.
So can I drive this now?I was actually talking about both options.
If you can get Iffor or an engineers report uprating the triple to 4500kg as per the axle limits with active brakes & the vehicle can take it a pre 19-01-2013 BE licence holder can tow it.
Or as above the pin weight on a 5th wheel is actually vehicle weight so a post 19-01-2013 BE can tow a real 4500kg (ish) as only 3500kg is via the trailers wheels.
Best option is say a 6T vehicle that had a 12T GTW down plated to 3500kg but keeping the full GTW with active trailer brakes on a pre 19-01-2013 BE licence. In theory you could get a real trailer weight of 6.5T (not much payload left after 5th wheel unit is fitted).
Or just take the C1E or CE tests & have what you need.
If its a 3.5t gvw tractor unit then yes with your pre 2013 b+e licence (if the trailer is rated at 3500kg or less then any b+e can drive it)
That depends on what licence you have & when you got it & the MAM MLPM & GTW.
Urban artics are the biggest clusterfuck going and best avoided.
A urban artic is not a artic.... 25ft artic carrying a 8 leg beavertail is a artic, same with tankers.
Urban artics are anything with a tractive unit under 18t, typically on either a single or tandem trailer and generally sitting at about 25t GTW. The reason they exist is really there Demountability and being able to carry a larger payload on a narrower lorry..... Trouble is sub 7.5t Urban artics aren't really worth a toss, you need a O license for the trailer and a MOT for the trailer.... Even on a 3.5t urban tractor unit.
I've researched them several times.... Namely because I've been offered 3 separate 14t Volvo FL220 tractor units and trailers (should of brought the first one) Basically unless your interested in carrying heavy long material your better off with a rigid.
Na, just a artic them.Oh right I always thought they where mini arctics and thought of urban arctics as the
32t+ setups running super short with twin or triple powersteered axles
Apart from brewery's I've not actually seen the sub 25t ones in person.
