L
Levelout
This is from carter diggers U.K. & NiHi,
The following is the a true description of the no end of problems I have with a CT08 digger. I would advise anyone considering buying one of these please read this or message me.
I'm not the only one though. Businesses who have bought these machines, certainly the CT08 have got rid. They have all said the same thing they hire the machine out and were waiting for the calls. My machine went out 5 days last week. I had to attend 3 times to fix.
These machines are poorly designed and use cheap materials. Metal I can only describe as plasticine..
Long list of issues include, electrical faults, flat batteries, starter motors failing, Hour meters is a constant failing. I have now come across a major issue that will affect all the CT08's and most likely other machine. The tracks will not stay on. Doesn't matter how many times they are pumped up with grease. After a few days they will be hanging.
I have now found out why the piece of plate at the end of the ram opposite to the idler wheel is like a cross shape. Its only welded on onside. The side the force is applied there is no weld. When force/pressure is applied this plate bends that is a mere 7mm thick bends back towards the idler wheel which loosens the track and off it pops.
These machines are not bullet proof they are cheap Chinese crap.
I would now advise anyone looking at buying a machine. Think twice about anything that has come from China. It is buyer beware.
A fool and his money are soon parted. I am that fool.
Firstly all the information has been logged on the system.
secondly if you have had these problems with the machine please supply the serial number and invoice of when you bought this machine . If we had been made aware that you were having issues with your machine, we would have collected this machine personally, and taken back to carter the U.K. importers yard to check the issues and rectify any issues .
We haven’t been made aware of any issues that you state with tracks coming lose. There are a lot of CT08 & CT10’s in the U.K. and apart from the odd hour clock and battery failure we have very little problems . But these issues are sorted once they have been logged with us (U.K. carter importer) if you have had a big problem with the tracks why haven’t you come back to us to rectify any issue . We can not fix them if we have not been made aware of the issue you are having .
Please go you the website and email me you contact information and serial number and copy of invoice of when you bought it along with images of the issues. We do carry all parts on the shelf and try and deal with every issue ASAP .
would have been advisable to come direct to get the importer to get these issues sorted as nothing can be sorted though a forum unless we pick them up .
thank you
Carter diggers U.K. & NI Ltd
