MacAulay Plant Services
wee_gus
wee_gus
Cat D3G undercarriage conversion, supposed to be first in UK, no photos of actual machine on customer’s request
wee_gus
wee_gus
Full hit on this Hitachi 130 in Telford, usual groundworker machine, as much slop in the tracks as inside the cab.
wee_gus
wee_gus
Terex J1480 undercarriage overhauled for National aggregate company.
New track chains and bottom rollers and sprockets
multiple cracks in both frames and main crusher welded
wee_gus
wee_gus
Bonnie weather tha past few weeks working up in the highlands at dornell wind farm for the highwalker Hyundai then upto gairloch for repairs on on hitachi
wee_gus
wee_gus
Main pump feed hose burst, the joint was behind the engine
Mark
Mark
Cat 352 with sprocket and drive issues, both final drives pulled and sent to machine shop to put in radial drill.
Strip and rebuild tracking motor and counterbalance valve
Sprocket bolts come slack and damage the final drive casing?
A
Alan caddy
We're you up in lewis the other day was working on side of hill when looked like your van went past, must have had to book a long time in advance
wee_gus
wee_gus
No, bolts had stretched
yea was up for MacAulays only booked on the Sunday, was in your yard to see Bam Bam also
A
Alan caddy
I was over breasclete and was pretty sure it was your van, did bam bam have you looking at there latest purchase round the back of yard
wee_gus
wee_gus
Few jobs out an about last couple of months.
Hitachi 480 ram seals, 17000nm the nut was torqued too.
Volvo inspections on Isle of Lewis.
Cat 352 repairs in Aberdeen
Crushing squad repairs
sunward with a design flaw.
No blade function, expander tracks also work off blade via a diverting switch.
also found out when you press the quick hitch button it disabled the blade so you use the baked lever to open and close the hitch.
lively little cat that we Carried out an undercarriage conversion on
wee_gus
wee_gus
Wacker duck for thorough examinations and some running repairs
wee_gus
wee_gus
Installing and commissioning a new sunward breaker into a sunward micro.
cat 385 with hydraulic issues in Inverness.
Check computer side with CAT ET then flow and pressure test machine.
Shear at fault
Remove dipper ram as suspect gland coming apart
wee_gus
wee_gus
Tested steel pipe on 14f Doosan. 1 hour walking to get to machine.
