R.Sanders Plant
Thomas7740
Thomas7740
Grey area.
Have had BC before questioning the depth of footings, but then it was Rory spec made ground..... Hard as f**k and unfortunately landscaped in so you can't see it.
Personally unless a Geotech comes in and does a compaction test it's a No..... Whilst I always engineer fill jobs like this bottom line is I'm not a Geotech.
For that reason I tend to dig through the fill. Or tell em to pile. Depending on the situation
Same as here then, foundations always on original ground.
Last time we did a cut And fill pad for a house, bco had us dig down to good ground then install 1200 concrete rings then fill them with concrete then ring beam on top of the peers. Was 4m or so though in places. We’d sheep’s footed it as it came up.
Be as cheap to odex pile it.
200 Series..... Pfft.....
I have our little Atlas Copco with A LD, MD and a Thor Hammer, alongside the Atlas Copco Rock drill, Air Pick and Air Disc cutter....... I might also of found the man to pilot it too.
hell of a commute though
Holman compair and coupla lads....pfft.
WTF is the totem pole doing in the middle of a car park Rory
hope you dug up the right car park and weren't relying on yer sat nav to find it :oops::oops::ROFLMAO::ROFLMAO::ROFLMAO:
f**k you all today, thankyou. 🤣
