got this on this morning .... forgot to take the pic 'til it was near dark ...
should help it stay put 'til I can develop the enthusiasm to replace the post .....
posty arrived lunchtime with ....
View attachment 23507View attachment 23508
Pam's been giving it her best afforts to break the repair this morning ..... and the spare'll be staying put for now
Couple of hours later Paul, our Hermes guy arrived with a package that could only be one of the two things I was awaiting arrival of .....
wasn't big enough to be the 10" diameter fan i was waiting for, for the countax .... shed it's blades late last year and in anticipation of some warmer weather (and on Angus's (
@modelman093 advice ) I'd ordered a new one .... so had to be
made up some brackets to get it mounted on the switch box plate off the Meddings ..
and got it in place .... after i'd sorted a supply lead into it on the bench .....
View attachment 23511View attachment 23512
re-cabled the motor on the bench with some 3 core and earth and got it back in its rightful place at the back of the drill ... and plumbed the new tails into the VFD, having sussed U, V & W's colours for getting the connections right ....
as previously discussed .... no cable clamping provision
so I'd used some longer than necessary bolts to fix it to its mount plates and tied both cables to those .... will at least give some protection .... certainly more than provided ....
nice fir, width -wise on the mount plate but had to extend it down a bit, to pick up the lower corners ..... with some 30 x 3 flat stiffeners ...
View attachment 23514View attachment 23515
VFD works a treat
.... and so does the drill
..... will be very nice to just be able to walk up and switch it on for the odd holes
...... all I need to do now is try and work out the various settings and programs available on the VFD's ying tong instructions ... you know the sort I mean
..... total bloody gibberish
the read out is capable of RPM, output voltage, loading, and preset levels BTLs .... just need to translate HTF to set it all from the gobbledygook paperwork that arrived with it.
weather looks grim again tomorrow
... so might have a play then .
can't fault it for the cost and's supposed to run 3HP .... don't think the drill's lil' motor is ever gonna stress it
