diggerjones
Looks a fair weapon
It came for the price of two rams I’d been looking at to build my own so was worth it. Local lad hires smaller ones for £500 a week so this was no brainer. Will do her up and help us with the 100 odd tons of stone we’ve got in yard that never gets usednow THAT is a stone cropper... must've been cheap for you to go high tailing it off on an impulse Giles ...
Not sure but it’s 40mm thick by about 150mm then 45 profile to hardened piece.what's the blade made of @Giles ? .... cutting edge ??
Stick.Uncle Druid I need some welding help please haha
will fire up the big Lincoln electric mig but any advice for a non welder appreciated
3.5mm rods?Stick.
Not the right man to ask tbh all i know is if you want it to last on a bucket repair stick.3.5mm rods?
as said in PM .... deep vee it, burn the paint off with a torch to get it clean and bang it in with the MIG ... 10-15 minutes as opposed to best part of 30-40 minutes with the stick .. and no inclusions ....... how do you suppose buckets are assembled guys? .... they ain't stick-ed up ....... a properly set up MIG will give you better penetration than a stick and unless you have a gas failure or loss .... zero inclusion riskUncle Druid I need some welding help please haha
2.5, 3.25 or 4mm Giles .... and if it had to be stick ... 3.25s, well juiced to get it burnt in well3.5mm rods?
I've just always assumed mig are OK on new steel but not the best with older stuff and you've greater choice or easier choice of filler rod.as said in PM .... deep vee it, burn the paint off with a torch to get it clean and bang it in with the MIG ... 10-15 minutes as opposed to best part of 30-40 minutes with the stick .. and no inclusions ....... how do you suppose buckets are assembled guys? .... they ain't stick-ed up ....... a properly set up MIG will give you better penetration than a stick and unless you have a gas failure or loss .... zero inclusion risk
as Thomas says Gaz, most ppl go for stick, 'cos they ain't got a big enough MIG to get the heat and therefore penetration ..... very few 'home' MIGs can deliver the level of current required for that sort of repair (or bigger) ..... a well wound up MIG set'll give you far greater heat and a bigger melt pool than a stick will. the welds tensile strength'll be equal to if not better than a smaller stick weld ....... and no inclusions to worry aboutNot the right man to ask tbh all i know is if you want it to last on a bucket repair stick.
What sort of amperage we talking Gra?as Thomas says Gaz, most ppl go for stick, 'cos they ain't got a big enough MIG to get the heat and therefore penetration ..... very few 'home' MIGs can deliver the level of current required for that sort of repair (or bigger) ..... a well wound up MIG set'll give you far greater heat and a bigger melt pool than a stick will. the welds tensile strength'll be equal to if not better than a smaller stick weld ....... and no inclusions to worry about
Agreed...... MIG does not like crap, but well prepared (cleaned) and it'd be my choice ... stick is a little more forgiving of crap as it'll float out in the slag .. to a degreeI've just always assumed mig are OK on new steel but not the best with older stuff and you've greater choice or easier choice of filler rod.
0.8 (or even 1.00) at about 180-190 A and it'll melt that back together in some order ... lay in a root to get it back together and multi run it ... 'paps give it a cap off at 200+ sprayed on but TBH a tidy multi run or woven will be fine and'll be as good as the parent materialWhat sort of amperage we talking Gra?
Tbf like most things its all in the prep.Agreed...... MIG does not like crap, but well prepared (cleaned) and it'd be my choice ... stick is a little more forgiving of crap as it'll float out in the slag .. to a degree
Cheers for that0.8 (or even 1.00) at about 180-190 A and it'll melt that back together in some order ... lay in a root to get it back together and multi run it ... 'paps give it a cap off at 200+ sprayed on but TBH a tidy multi run or woven will be fine and'll be as good as the parent material
