video links thread anyone??
some Extreme digging and love the use off the timber harvester base
Nacap Lawrence took a welded 48" gas main up and over a similar bank here many years ago, above Hafodrynys .... having come down an equally horrendous bank to the A472 main road at the bottom of the steep Vee sided valley and tunnelled under it :oops: ...... everything was on winches
best pic I can come up with on this new beast .... and took a bit of sussing :rolleyes:
Couple of interesting ones:
One for @V8Druid :
And this is just bonkers ...only in USA...bit about lack of brakes is amusing😲🤣 (21:20 onwards)
Daz (exmayor on the old forum) was involved with the transport on the train job i believe
here's one i put up on CEF a long time ago ..... pretty impressive really considering it's all grass .... 'Praps Pam could start crocheting stuff out of our grass cuttings next summer :ROFLMAO::ROFLMAO:
and this is an interesting solution to a PITA problem I tripped over earlier
way too much throw in that .....would've vibrated like hell in use ...... look at the main face :oops::oops: IMHDO .. too small a tail stock?? :cry: ... alarm bells should've rung when he end for ended it and it was throwing on the clock at the chuck
just watched part two :oops::oops: so all the cert.s in creation mean sweet FA if you still end up with shite material ... even if the cert says it's good :mad:
once had a similar issue with supposedly cert.ed stock which could've proved disastrous ... making special lifting toggles ... all failed load testing ... had 'em metallurgically tested ... wrong material ... stock holder ended up paying a very big bill for ALL the costs(y) ...
nice piece of work and loved the tail stock chuck to set up for min. throw initially ... anyone watch this one after
Watched most of his vids (y)
