Do you not realise this is really passed my bedtime and anno what you you call them was never my think!!Annoys Gatekeep Stumpy.....
Rearrange the letters.
Seen that, apparently they got her out but not before tide swamped her till the next dayLooks like MJ Church are having a bad day
Also shows you’ll never get bogged plant off a wet sandy beach with a rising tide without a serious winch - the suction is phenomenal.Knowing all the method statements and paperwork I’m surprised there isn’t something for machine breaking down on a beach. I seem to remember @JD450A working on a beach a while ago and having a machine for recovery if anything went wrong?
Exactly what I'd have done, good man.Seen rob taylor post on FB about the plant fitter took out all ecus and blocked off all ports on engine to hopefully bring it alive again
Enough to get it on a boat to AfricaExactly what I'd have done, good man.
Not sure I'd want to keep it much longer afterwards, mind.
Absolutely they did drag it out with a big winch.They did have a big winch truck there and it did the work as I seen in other pictures somewhere, it had its line doubled up a few times and anchored to a couple of Volvo dump trucks.
I think the machine where just there to steady it up and stop it going over
doubt you could even see it at high tideLooking at the news article there is a photo of it under the water anyway. So the digger is obviously going to be an insurance claim.
A combination of everything I’d say. Dig around it where possible to reduce the ‘ground anchor’ effect and potentially open up a ramp to climb out of the hole. I think in the beach recovery they also used a couple of diggers to pull either way on the stuck machine’s boom to wobble it in the hole to try and break the suction as they winched it.So, what is the best recovery method? Forget anything moving to try and pull it out and get a winch with enough cable it can sit on firm ground and just grind it out?
The tide cannot be stopped - if you break down or get bogged you are in the shite very quickly.With anything involving boggy/waterlogged/wet sand etc you've got to get on to of the job straight away. That's why people have said on facebook if you're working on the beach have recovery there ready at all times. When it goes wrong the more you mess about the worse it gets fast.
a slow steady pullSo, what is the best recovery method? Forget anything moving to try and pull it out and get a winch with enough cable it can sit on firm ground and just grind it out?
