diggerjones
Anyone used the tobermore blocks for retaining walls. The customer fancys these. At least hes off the gabion idea
did you show him the allan block the guys are brand new to deal withAnyone used the tobermore blocks for retaining walls. The customer fancys these. At least hes off the gabion idea![]()
He's gone for the colour. Allan block probably don't do the slate shade he wants.did you show him the allan block the guys are brand new to deal with
There's about 10ms at 1.6m.What height is the wall you're building?
Colinwell - Allan Block Retaining Wall Systems do a slate slate blendHe's gone for the colour. Allan block probably don't do the slate shade he wants.
It'll depend how you plan to actually build the wall. There's two ways with the hollow block types (i assume they are faced hollow blocks) either build on an angle stepping each course back which i think can be off type 1 or if you want plumb it'll likely be conc found rebar up hollows and fill with conc. Conc will be easier than type1 to get flat for first course either way and would be bestThere's about 10ms at 1.6m.
The rest 1.2m.
It's says concrete footing or compacted type 1. Any thoughts?
I will show customer. Depends on who's got what in stockAre you a rep![]()
The ground is pure sand at the footing. Access is not good at the moment, lots of mud. So want to push compact stone would be betterIt'll depend how you plan to actually build the wall. There's two ways with the hollow block types (i assume they are faced hollow blocks) either build on an angle stepping each course back which i think can be off type 1 or if you want plumb it'll likely be conc found rebar up hollows and fill with conc. Conc will be easier than type1 to get flat for first course either way and would be best
no got nothing to gain myself but when i find a product and a supplier that are good to work with i have no hesitation in passing that on it so difficult to find decent people to work withAre you a rep![]()
The thing is if you use stone and can't get first course bang on every following course will be off or even get worseThe ground is pure sand at the footing. Access is not good at the moment, lots of mud. So want to push compact stone would be better
You haven't seen my concreteThe thing is if you use stone and can't get first course bang on every following course will be off or even get worse
That might work. Customer has a cad system so likes that stuffif you go on to the allen block web site you can even down load an app to design your wall tell you where to put your geogrid the amount of blocks ect
it is a bit of work to put the info in if you are interested even got video's on that youtube to teach you how to do it
at 38 kg each you know about it by the end of the dayFull artic load.when i said to the rep I'd got a grab for the digger, oh he says you won't need that
