Mogmans creations 🤔
New incarnation of me old dumper
Log skidder (y) the A frame at the back just touches the floor when lower and you can see still got a fair bit of travel on the lift side of things too welded a few clutch hooks to it along with a normal hook in the middle and a tote box for the chains
For fucks sake i've just had a shower.... off I go to the toilet again..... 😂 😂
were you looking for some of these a while ago @Mogman 1821123 2500KG 335MM Bags Lifting Carrying Hook | eBay
G
Gez_lewis
i use 2 of them hooks on a short chain to winch cars onto the recovery trucks- hook them on the lower arms or any where really, winch brothers we call them.
Just to piss Rory off😳 collected this digger and trailer for less than scrap value🤔a lot less👌
there is a problem with it one of the Tyres’s is flat😩 oh and the diggers engine is worn out so I’m told🥺 will stick a battery on her tomorrow and see what happens, think it may need rings🤔 if so will pull the engine out👍
T whiting
T whiting
Was it strapped down when you found it???
Doesn't looks a bad machine especially for the price!
On a serious note I have a buyer for that trailer :unsure:
On a less serious note put the digger on the load..... :ROFLMAO:
Well I’ll sell the trailer👍 going to look into the engine problem and make a decision whether I move it on or keep it
Message me what you want for the trailer, i'll relay it on.
Stubota86
Stubota86
tack weld some trailer wheels each end of the tracks, paint the top of the K in and send the new Romatsu off to China
What a horrible thing to work on😩 if the starte motor needed replacing you have to d this
side weight off with side panel, cooling pack out (oil and water), fan out and alternator removed then you can just see the starter behind the engine by the bulkhead😳
and to remove the engine you have to take the hydraulic tank out to get at the engine mount bolt which is between the hydraulic pump and starter motor but can’t remove the tank until the pump is removed so have to unbolt everything and just wriggle things about🙄
anyway all out and steam cleaned ready for the next step⚒
View attachment 21488View attachment 21487and to remove the engine you have to take the hydraulic tank out to get at the engine mount bolt which is between the hydraulic pump and starter motor but can’t remove the tank until the pump is removed so have to unbolt everything and just wriggle things about🙄
Could you not get to the starter through the cab through that hole?
What engine is in it?
Have you still got that big Cummins from the Ford de-icer you wouldn’t sell me?!...
diggerjones
diggerjones
So what was it like before. Was the engine knackered. Is everything else ok.
The hole is in the wrong place plus the alternator is in that hole😳
komatsu badged yanmar
Yes but wouldn’t be a zero tail swing with 4 of the 6 cylinders poking out the back😢
