Pipe Lasers
Matt
Looking at the possibility of getting a pipe laser as the job we are starting in January has a lot of drainage with shallow falls so can’t afford not to be accurate.
Have plenty of experience with drainage but normally use a standard above ground laser level. Looking to be more accurate and efficient with a pipe laser.
Done a bit of research and like the look of the Spectra Precision DG613 or DG813. The Leica Piper 100 looks good as it fits in 100mm pipe but don’t want the faff of changing the little legs all the time.
Just wondered if anyone had any experience setting them up/ using and how difficult they are to use well? Any advice on make/model appreciated too.
Thanks
Matt
Thanks
Matt
Not used one for a good 9 year plus, they are handy. It was the Leica version easy enough to use, came with a little gradient book to quickly set it up without have to work out the input settings. The legs have two jobs centering the laser in the pipe and also raising the unit so the beam is centre of the pipe
T whiting
T whiting
There a all right tool and very good at keeping your pipes straight and very simple to use but you can achieve the same results with a rotary laser.
There not much use on runs less than about 20m as you spend so long faffing setting them up it could've been finished with a rotary laser
G
Grifferr
Not much good when using 6m lengths of pipe as you can only check at each end. How do you check halfway along the length. Some 4 inch pipes have a 4 inch bow in them!
T whiting
T whiting
We put them on top of the pipe or a couple of rings up a PPIC then lay a bed of gravel to lay the pipe on and you can check the top of the pipe with a stick you can't lay the gravel with a shovel as easily though
Left hooker
Left hooker
Cut them in half and fit a joiner
South west water won't allow pipes over 3m to be used on main sewer jobs for this exact reason
But surely checking with a rotary laser by passes that problem
I check all pipes every meter regardless of laying to turn of the bubble or something more exact
And some one above mentioned leveling the shingle bed with a shovel
I have an earth rake cut to six inches wide it is far quicker and easier to level the bed out and no need to get in a trench with i struggle with in deep 200mm trenches anyway
Matt
Thanks for all the replies. They do sound like a bit of a faff to set up. Perhaps just setting up the rotary laser on a single axis slope might be a better option. Most of the runs are 20-30m.
All the main runs of foul have to be in 150mm clay so won’t have issues with the 6m pipes until we get to the laterals, but that was a good point as they are often like bananas.
All the main runs of storm water are 225mm upwards so hoping they will be fairly straight.
I like the idea of the narrow rake. Might have to do that!
Cheers
Left hooker
Left hooker
One thing with the water boards of your respective areas on mains work like of south west water in my area your not allowed bugger all deviation gps will mark center of manhole runs gradients have to be as to plan so a pipe laser will give you a truer pipe lay than rotary laser for side to side and up and down so 3m lengths keep it more tight where's 6m lengths are like bananas to lay
Also pipe laser you can mark the back of a shovel to use as a guide for gravel bed prep leaving it slightly lower to allow for joint
Stuff from road to house and around property rotary is fine as no one's checking deviation
I’ve used a Leica pipe laser for years I’ve had it at least 15 years and it still works perfectly . I wouldn’t be without it now . It’s great when you don’t have much fall or when the ground is running in the opposite direction of your pipe fall but I use it whenever I can . When you get in the habit of using it it actually takes no time to set it up. I usually sit it on a concrete block and I level the dig and then the pea gravel . If you get that right you hardly need to check the pipes .
Far more important bit of kit than any tilt rotator for a Groundworks outfit ! But that’s just my opinion .
vin
vin
I concour.
F
fred
not the same pipe.
severnttrent insist on the black ribbed stuff on their side not the standard 110 smooth. Lot more expensive and doesn't bow half as much.
Left hooker
Left hooker
not the same pipe.
6 inch and up in plastic multi rib is used
CST/Berger 59-LMPL-20 CST/Berger Electronic Pipe Laser Kit
LAST ONE IN STOCK!! SOLD OUT MODEL!!!
ONE LOW PRICE: 2,999$ CAN
We ship anywhere in CANADA or USA FOR FREE!!!!
CST/berger brings an unparalleled expertise to designing, developing and manufacturing leveling and layout instruments. CST/berger tools and accessories are built to survive the toughest jobsites and packed with innovative features – leading the way for the building, construction and survey markets
The CST/Berger Pipe Laser 59-LMPL20 combines productivity and functionality for manhole, sewer, and pipe construction. Dual axis self-leveling gives the LMPL20 the ability to respond quickly to grade adjustments. It has a LED Light on top for plumb reference. Additionally, the CST/Berger Pipe Laser is waterproof and lightweight with an accuracy of +/-10 arc seconds. It comes with a remote control that works from a distance up to 800 feet.
Self-Leveling Grade Setting and Lock
Using its laser point, the LMPL20 Pipe Laser allows construction professionals to measure grade in a range of -15 to +40%. The laser adjusts horizontally at a range of +/-15%.The Auto Grade Zeroing feature returns the pipe laser to zero-grade (no incline or decline) while the Auto Line Centering feature resets the pipe laser’s line range to zero. You can control these functions by inputting your grade into the LMPL20’s keypad and the results appear on the large, LCD display. With its special locking feature, this pipe laser will not lose its settings if moved after setup.
LED Plumb Light
The CST/Berger LMPL20 contains a LED Plumb Light for plumb reference to verify that your vertical line is accurately aligned. And with this pipe laser you can always achieve the precision and detail you need on the first attempt.
Wireless Two-Way RF Remote Control RC20
Construction professionals can control the pipe laser as far away as 800 feet with the Wireless Two-Way RF Remote Control RC20. The remote has its own LCD display and controls every function of the pipe laser. So climbing in and out of the sewer is no longer necessary. The auto shut-off function preserves your battery even if you forget to turn it off manually.
Waterproof and Portable
The CST/Berger 59-LMPL20 is thoroughly sealed to function in damp conditions with an IP rating of 67. It weighs just over 10 pounds, so you can easily transport it wherever you need, including pipes with diameters as small as 8 inches.
656 ft. laser range
+/-10 arc second accuracy
-15% to +40% slope
LED plumb light
IP67 dust and waterproof
5/8 x 11 tripod thread
How much for cash?😎
Digger126
vin
Hi vin, do you set the block up in the centre of the manhole at invert. Cheers
Hi .
You don’t need to put it in the channel at all .
You can put it on the ground above if you like . Just use a wee boat level to level up your block on a bit of sand and have the block pointing in the direction you want to go . Put the laser on top of it and type in your gradient . Then dig down in front of it to the depth you require . When your dig depth is perfect put a vertical stick on the bottom of the trench and mark the point the laser hits it . This is now your traveller . Carry on digging and when your mark in the stick lines up with your laser then your at the right height . If you want 50mm bedding put a mark 50mm lower on the stick and then use it to regulate your bedding height .
Have you bought one ?
Hi .
If doing that why not just use a rotary laser with grade control. Then you can use a receiver. That's what I've always done. Never done long enough runs to warrant a pipe laser.
I’ve got rotary grade laser but it’s not as quick as the pipe laser . Once you’ve put it down your away and you can move it along quickly when you need to . Great for runs around houses etc but if you wanted to use from cab of digger then you’d want rotary grade laser to work with likes of idig . I’ve had my pipe laser before any grade lasers were available and used it for loads of things .
