Matt
Looking at the possibility of getting a pipe laser as the job we are starting in January has a lot of drainage with shallow falls so can’t afford not to be accurate.
Have plenty of experience with drainage but normally use a standard above ground laser level. Looking to be more accurate and efficient with a pipe laser.
Done a bit of research and like the look of the Spectra Precision DG613 or DG813. The Leica Piper 100 looks good as it fits in 100mm pipe but don’t want the faff of changing the little legs all the time.
Just wondered if anyone had any experience setting them up/ using and how difficult they are to use well? Any advice on make/model appreciated too.
Thanks
Matt
Thanks
Matt
