it's only "a good scoop bucket " Stock, if you have the Miller hitch that it fits ontoNo impressed with you screwing up a good Scoop bucket..........................................................
it's only "a good scoop bucket " Stock, if you have the Miller hitch that it fits onto...... and the ears I've attached to it will come back off in ten minutes if you did .. as it is, it's a good use of serviceable/brand new bucket that has a very limited market ......... and was too cheap to say no to
It's more the fact you're hitch has to fit inside the top of the bucket.what size pins did it have then, to be a limited market?
And no other quick hitch will fit?It's more the fact you're hitch has to fit inside the top of the bucket.
Dunno probably but how many i don't know.And no other quick hitch will fit?
Imo you might find one with too much metal in the wrong spot, but I can’t see why most of them wouldn’t fit. Any bucket has the same thing, two bits of plate with pins between them, just because they are set into the top of the bucket doesn’t make any difference in my view.Dunno probably but how many i don't know.
I may be wrong but looking at the pics one issue may have been that his hitch was too wide fit.Imo you might find one with too much metal in the wrong spot, but I can’t see why most of them wouldn’t fit. Any bucket has the same thing, two bits of plate with pins between them, just because they are set into the top of the bucket doesn’t make any difference in my view.
Gra’s Hydrema is on 70mm pins and I’m guessing a 270-280mm dipper width? That Scoop bucket looked like it was on 65mm pins, and circa 250mm dipper width, at a glance, which would probably be the most popular pin size on 12-15t machines.I may be wrong but looking at the pics one issue may have been that his hitch was too wide fit.
There could be something they designed in spacing wise just to make it so you buy all your buckets off them. They made those scoop buckets for smaller diggers (probably still do) and I'm sure they were slightly different to most others.Gra’s Hydrema is on 70mm pins and I’m guessing a 270-280mm dipper width? That Scoop bucket looked like it was on 65mm pins, and circa 250mm dipper width, at a glance, which would probably be the most popular pin size on 12-15t machines.
I was just curious as to why Gra said it had a limited market? So it must be a strange fitment?
Makes a big difference to the digging and breakout force which is why the were made, Had a scoop on a 450 volvo with a Dromone hitch, so it must depend on what machine it was originally ordered for.................................................................................. great bucket though.....................................................Imo you might find one with too much metal in the wrong spot, but I can’t see why most of them wouldn’t fit. Any bucket has the same thing, two bits of plate with pins between them, just because they are set into the top of the bucket doesn’t make any difference in my view.
Maybe for optimum performance, but other hitches will fit.FYI scoop buckets and hitches have a weird geometry to fit..... Hitch has to be right for it, not just any pingrabber will do.
Is that an Oriel?............................................if it is then, it is made by the original owner of Geith engineering which were bought by Doosan some time back....................................................................................................which I believe to be a rebranded Geith,
that was my understanding too Rory .... as said those pins are deeeeeep in the bucket's internal cheeks ... not just any old hitch'll doFYI scoop buckets and hitches have a weird geometry to fit..... Hitch has to be right for it, not just any pingrabber will do.
No it’s a JCB branded hitch, looks like a Geith to me?Is that an Oriel?............................................if it is then, it is made by the original owner of Geith engineering which were bought by Doosan some time back....................................................................................................
