I’ve used the Hydraulic Magastore from Grimsby for online hoses, come next day, seem very competitive.
While we are on the subject, has anyone found decent quality aftermarket hoses that actually last? I find most start perish with in a few years. But the original Gates hoses on some of my machines look as good as new 10+ years down the line! So what’s different? Do OEM’s insist on better quality? And the as the aftermarket is probably price driven, so the quality isn’t there?
Our loca outfit used to supply Gates, now they’re on Manuli. Manual I tend to be a bit stiffer, other than that no issues.Biggest issue causing cracking is how you route the hoses, and the correct length. Even on a longish hose, half-inch either way can cause more cracking of the outer sheath. Another one is how you use the natural curve of the hose, if you’re fighting it the hose won’t last as long, especially on bigger bore hose.
