I've been looking for it.... going to ring Pam tomorrow and see if she wants me to outbid him to spare her another moss covered eyesore in a year or two.
you're pushing your luck after waking us and more particularly PAM, up at 08.00 this morning matey :p:ROFLMAO:
You need a wake up call once in a while.... Keep you on your toes 😂 Your lucky it wasn't at six.
no ...... you are ... you'd have been having a conversation with Pam at six :oops::ROFLMAO::ROFLMAO::ROFLMAO:
right chaps (and chapesses-if we have any??) .. and Aiden @CPS .... WTF am I gonna find one of these ..
the cause of the leak
will give my local guys a call tomorrow
as you may guess, the above is the gland seal out of the Cranab ram .... little bitch it was too .
step one .... evacuate said ram of liquid gold (also known as Plantohyd ;)) in a controlled manner :ROFLMAO: .... saves a lot of cleaning up of 2 litres of oil
step 2 find out WTF is lurking behind the cover plate
I had actually sussed it by this point and had installed the SHCSs to deal with it ... had spaced said cover out to get a hold of it with the 4 ft stillis to rotate the end cap lurking in the cylinder to free it off ... so's I could tap it back in
to reveal this gert spring clip
which took some extracting
tapped it in first to get an end out the groove, to get under it to get behind it with this
can't recall what I made it for maaaany years agom to pull summat out of somewhere, :unsure: but it's done a few little jobs over the years ... and worked very well on this one too :giggle: that was some spring clip - 6mm and serious
some compressed air into the extend port and this popped out, sweet as, after id give the neck of the cylinder a good wipe clean first, of course
grub screw located and removed and it came apart sweet ...
somebody else'd been in there at some time .. ****ing butchers :(:mad:
all it needed was a decent sized adjustable (see previous pic) and came off - "simples" ... allowing access to the gland/end cap
which simply slid off :giggle::giggle:
the acetal bearings were a POP ....... the seal on the other hand took some persuading out of where it lived
piston pack looks fine ... all off and cleaned ...
as does the dirt scraper seal out of the end cap
not a dint or mark on it
and i'm out o' pix again
Il check my big box of odd ball sesls tomorrow for you👍
cheers Aiden .... losing a lot of oil considering the small defects ... but does have 180 bar trying to escape .... couldn't see a cause though :unsure::( rod looks and feels fine .... like the proverbial baby's bum .... :unsure::confused:
whilst I had the beast securely tehtered to the bench I bumped the base bushes out as the one had worked its way into the centre, as it was devoid of a spacer ....
went back in sweet ...
I'll make it a 3/4 spring spacer tomorrow and slip it in there ... nowt available to suit the bore size today ... 59 milly is a weird size :unsure: andno lathe :( to make a solid one up 😡
everything clean and sat indoors tonight ... awaiting a new seal .... 's a lump of a rod :oops:
as you'll have guessed from the clear bench .... the Cranab went back together this morning ... well late morning after me hamster juice session ..
one in POP ...
then juggle the other half in ..... VA-r made it relatively simple ..
pinned in and ......... in with the link rod
bit 'floppy' without a ram installed ... but only as far as gravity allowed
got it horizontal for a very controllable hand operation to grease it all up
new nipple required as it spat it back out when it got 'operated'
job did ..
ratchet strapped it closed for now and a couple of timber spacers between the ram pins for good measure and ...... I'm out o' pix AGAIN !!
....... and dropped it off the bench ....
looking a lot tidier, even if I do say so myself :giggle::giggle: ... did um and arrr about blacking the pins, but could always do them again , a pin at a time ;) ....
wanted it off the bench ........ just got a few scratches/battle scars to touch up on the tongs ...the Druid gold hadn't really had time to harden off properly :rolleyes: like glass when it's left a few days/a week (y):giggle:
more pix of the ram dismembering here if anyone wants a blow by blow .... https://s1275.photobucket.com/user/v8druid/library/buckets?sort=3&page=1
Mark
Mark
Thoughts on this rod Druid?
Will be getting done under warranty by finning, got them to replace rod and reseal it last august. Month or two later started scoring like so, perfect scoring length wise on the rod and 360 degrees. Got another new rod and resealed in January and done the exact same again only 300 hours on so on this rod and done the exact same.
Something wrong with the end cap/gland?
Has it got a cushion in the ram?
Had a very similar thing in a dipper ram, old machine, but had a big collar behind the gland, it looked fine, but was picking up on the road and ruined it.
