Noticed last few times I have been on 8t that its getting a bit crunchy sounding from the idler end - what sort of a job is replacing he bearings in the idler ?
Might just be easier to change the lot? Maybe @wee_gus can offer some advice?Evans and Ried supply only complete idler and side arms.
Hard to say, lots of machines will never have the idlers replaced at all, other like yours will fail. They probably had some oil in them at one time, seals went along with the oil and that’s the end of the bearings probably! Just one of those things I think. Has it done both sides at the same time?Yeah maybe... I have never had to do any before - been quoted 370+vat plus 80 carridge
so if I can change the bearings might be worth the hassle
5400 hours on Kubota 8t- 7250 hours on last JCB 8t and never had any similar probs, is it bit premature ?
Dont know James.... on it next week and will check - might be a change lot job like Rory says.Hard to say, lots of machines will never have the idlers replaced at all, other like yours will fail. They probably had some oil in them at one time, seals went along with the oil and that’s the end of the bearings probably! Just one of those things I think. Has it done both sides at the same time?
I ordered one last week from excavatorpartsdirect.co.uk
It’s probably because it’s a s**t of a job and you’ll probably need a big press to do it?You would of thought it would be worth a go - if they both want doing it will be £850 +vat inc carrage bearings should be a fraction - funny how I have never seen the bearings advertised seperate though![]()
Bit like Ifor with their wheel bearings.... a lot of mower manufacturers grind the bores in their bearings so you have to buy from them at four times the price![]()
they do it too do they .... bar stewardsBit like Ifor with their wheel bearings.
Cheers - will change the lot when it's back at yard ..... probably be ChristmasFor the time involved with stripping down the idlers 99.9% of customers replace the whole idler assembly. I have done the bearing in the past but it wasn’t worth in my eyes
