Idlers crunchy
Noticed last few times I have been on 8t that its getting a bit crunchy sounding from the idler end - what sort of a job is replacing he bearings in the idler ?
Regy53
Regy53
Administrator
should be easy enough if it press's in... track off idler should pull out and press the pin out. away you go
I have emailed
Evans and Ried
any other suggestions ?
Cheers
Evans and Ried supply only complete idler and side arms.
Yeah maybe... I have never had to do any before - been quoted 370+vat plus 80 carridge
so if I can change the bearings might be worth the hassle
5400 hours on Kubota 8t- 7250 hours on last JCB 8t and never had any similar probs, is it bit premature ?
Hard to say, lots of machines will never have the idlers replaced at all, other like yours will fail. They probably had some oil in them at one time, seals went along with the oil and that’s the end of the bearings probably! Just one of those things I think. Has it done both sides at the same time?
Dont know James.... on it next week and will check - might be a change lot job like Rory says.
I've asked dobson's if you can buy bearing separately...that will decide it.
T
Thediggerman
If you can get the numbers of the bearing then BRT BEARINGS should be able to match it for you.
You would of thought it would be worth a go - if they both want doing it will be £850 +vat inc carrage bearings should be a fraction - funny how I have never seen the bearings advertised seperate though :unsure:
It’s probably because it’s a shit of a job and you’ll probably need a big press to do it?
unless the bearings are ground to fit non std sizes, you should be able to get the bearings simply by measuring the old races ... a lot of mower manufacturers grind the bores in their bearings so you have to buy from them at four times the price :mad: :mad:
wee_gus
wee_gus
For the time involved with stripping down the idlers 99.9% of customers replace the whole idler assembly. I have done the bearing in the past but it wasn’t worth in my eyes
Cheers - will change the lot when it's back at yard ..... probably be Christmas 👍
