All good points and yes, some of my logs (like the one above) have been under floodwater and has traces of silt. However, even on clean timber, a steel chain is very dull.
by the time the tank is empty. The last few cuts are always a balance to decide when the chain is "blunt".
A interesting point about carbide not being as sharp as the first cut with steel, but certainly sharper than the last 80%.
Lubing is also an interesting point. The oil pump is direct drive, so the volume of oil delivered is solely dependent on engine speed, not load. If you load up the saw and pull the revs down, it won't get a lot of oil regardless of the chain you are running.
