Can you rivet them together, its what we do with the cast iron ones good bead gutter sealant then rivet them but they are generally on rise and fall brackets
No, that’s the problem with plastic. It has to be able to move and slide on the couplers (I always replace the seals and grease them). If you rivet them together the whole line will just warp and twist when it gets hot. The problem here is that the brackets pivot also, so joints regularly pull apart.
A high modulus silicon can sometimes work as a halfway house- not too much, and hope that it can stretch enough. Underneath the joint- the seal still does the sealing.
Today we are definitely not stealing @Storrsy s work.....
Bastard job. The hazel stools need to be saved and cut down low, so instead of pushing them over and piling them up I’ve been ripping the tops out and then cursing trying to cut the stems without my chain coming off.
Went and got the 462 with a 20” bar, it’s much better than picco chains for this.
Did I mention there’s an old wire fence in places too? 🤬
At least it was close enough to run the tractor down the road first thing rather than wade around in thistles and brambles all day.
At least it was close enough to run the tractor down the road first thing rather than wade around in thistles and brambles all day. View attachment 85283View attachment 85284View attachment 85285View attachment 85286View attachment 85287View attachment 85288View attachment 85289
i have a tmk300 i dont use ..
I’m still jealous of that backhoe even though I know they’re not for me.
It's been one of those jobs where it makes sense. Access is a mile up a Storrsy style Lane. I have been here before with the 175 but that was a job that needed it.
I've bulked out a 15x30m reduce dig and topsoil strip this afternoon..... The Terex is a weapon on the front.... Pity about the back.
It was the Storrsy kind of lane that became the stumbling block the 2nd time I was asked to quote it🤦 Asked the chap I was dealing with to get landowners number so I could arrange access for stone drop offs coming in and they never got back to me, usual grab lorry I use looked at it and said wouldn't be able to get up there so was just going to dumper the stone up the road.
Should of rung as I'd of chucked you mikes number, although the other entrance up to his house is equally s**t. I did think it sounded like the one we chatted about when I put the ground source heating in but thought that was pissing years ago so can't be the same one. Sorry 🤣
Might still be a problem..... NR reckons they will get 12t wagon up the lane 🤔
Some mad bastard is up that way with a 14t Hyundai too
I looked at it in 2018. DNPA didn't turn up leaving me and the farmer making small talk for an hour. 2nd time was summer last year- this time they actually had an idea of what they wanted to do but when trying to sort out the finer details it was like trying to get blood out of a stone, trail went quiet so thought me and that job just aren't meant to be😂 Agree wheel digger just the job for that👍
