Thwaites drop box oil leak
Mike_510
Hi
New problem, got a leak from Dropbox on Thwaites all drive 4000, not massive leak but annoying as nearly all the other jobs are now complete and just needs painting.
Does anyone know it if oil seals are available, having difficulty getting part numbers.
Is it a big job, I don’t think they tapered bearings, so don’t the think the hubs need to be preloaded when refitted,
Anyone carried this out themselves any advice.
Thanks.
Hi
Thanks.
There is a firm West Country way who will supply you everything you need, probably just from a description of the dumper. Forget the name. @JD450A will know for sure.
Mike_510
Managed to find the newage Dropbox manual, unfortunately it doesn’t provide part numbers.
Steve
Plant & engineering services in Devon would supply all parts & probably supply an exchange drop box if you didn’t want to do the job yourself. Worth stripping down first to see if you have any other underlying problems that caused the seals to go ie bearings or pitted shaft If you plan to repair it yourself.
Mike_510
From the look of it, just looks like seal is damage by dirt on the front, can’t feel any movement on the hub, so was just going to try the seal, had quote for 850 for replacement, to rich for my blood, I could probably rebuild it if needed, but just hoping to replace the seal, 🤞.
You wouldn’t happen to know the sizes, did email pes, but needs the information of the tag, I’m not home for 2 weeks and was hoping to get delivered before I got home.
Mike_510
he used to operate out of a small shed in Raglan in the '80,s ... haven't heard that name for years
Yeah I got my spool valve from him, he has new box on the shelf, £850 though, I’m hoping just to replace the seals and bearings worse case scenario, he is getting back to me with price for seals, but not as of yet, he did say he was busy.
Your leaking seal is 35, isn't it? Probably the same as 34.
Shout yourself a new grease nipple for the uni-joint while you are under there :ROFLMAO:
Mike_510
😂 changed them the next day,
You don’t know anything about the clutches on these Thwaites alldrive dumpers, seems like a bit of play, only got about a 1 and half inch of actual bite, some said maybe the release bearing is worn.
Not me, no.
I had a clutch diaphragm spring warp and that presented as a very light clutch with only a short stroke.
When a throw out bearing fails, it typically makes a horrible sound as soon as you press the peddle - anything from a coarse rumble (which you may feel coming back through the paddle) to a high squeal.
Mike_510
Make sure it’s not the engine moving on the soft mounts! They used to!
Definitely the clutch arm, of the 3 inch travel, 1 and half of it doesnt move anything inside the bell housing, then you can feel the clutch engage, might be normal for them, just feels strange.
Mike_510
Not me, no.
No noise or anything, just feels really strange with such a short engagement, in fairness it’s not jerky, and you can start off quite smooth, just feels strange.
A warped pressure plate will be jerky, but a warped diaphragm spring just feels soft with a short stroke.
Clamping force will also be low making it easy for the clutch to slip.
