yep -- it's massively disappointing how that stone has fallen apart ... came out lovely - blocks in a couple of beds all flat as :rolleyes: ... looked like it'd been laid
and thanks for the complimentary comments .. always hard to tell on this sort of thing how it looks, and get little 'input'/comment from Pam :rolleyes:
got a plasterer coming Monday to give it a skim coat :p:p:ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
just found some pix Jim ... had two layers like this
WP_20180630_19_36_54_Pro.jpg WP_20180630_19_36_59_Pro.jpg WP_20180701_18_37_17_Pro.jpg
Bucket on wheels
Bucket on wheels
Here is inspiration for you new gate 😱😵‍💫😆🤣
won't keep many rogue sheep out though Frank
today's mission ... scrat the hell out of the rock hard ground as instructed ... teeth required :giggle:
Haner off and teef on ... first time I've had one of the buckets that came with Lil' Jake on him ... bloody heavy too - hence the sack truck - sod carrying that, from the patch all the way down the garden
ground duly scratted :giggle::giggle:
extra soft tish won, relocated as required :unsure:
Haner went back on to aid chucking a bit of the spare up out the way then time for a late lunch
and some tidying up after it .. overcast so garden watering time, early, followed by tea ... and not a lot ;):rolleyes:
hamster juice knackers Sunday mornings so didn't get going 'til after lunch ...
bench time required ...
I'm glad I put a new mask on to wire brush that old manhole lid with the 5" Mak and wire wheel .... dust - unbelievable :oops:
then set about creating a new frame for it as it's not the original lid and that plastic surround/base is a piece of crap -- did outlast the tin lid though :rolleyes:
had to get the tarp cover rolled back off me steel stock, to find what i wanted, buried under heavier stuff ... worked a treat - forgot to get a pic though - real easy :cool:
start of the frame ..
then set an inner lip to get the top height right and give it a bit of a seal too
frame in the background is to support the lid's surround
stitched together ......
and firmed up
second trial fit ... first one 'fore I joined the two bits
and yes I tried it in the chamber too
coat of supposedly shiny sh1t ... which is more of a satin finish .. dries quick though and seems to hang in there well
the boss wanted the top of the lid Pewter (looks a bit like galv TBH) ...
so ....
good as new :giggle::giggle:
gonna wait 'til it's been emptied Tuesday, 'fore I go fit it ... boss is happy though :rolleyes:
had a lovely 'mackerel sky' last night
this guy really does NOT like the heat
barely been indoors other than to eat for weeks - both of 'em find the coolest spots they can and sleep through the day
got a third coat of black on these Monday evening
ready for an install yesterday .... which didn't happen ... Kevin was a lot later tan he anticipated
tank emptied for another few years .. only two of us 98% of the time and takes a while to fill it :giggle::ROFLMAO: .'s a big tank ... TBH it could probably have gone another year or so ... wasn't giving any issues whatsoever, but with the weather like it's been and zero ground water issues currently, seemed a good time to go for it
didn't sleep well Monday night and was glad he was late .. was knackered 'fore I even started Tuesday
must've had 5 ish mil of rain last night ... at least that sat in the inverted lid this morning
got the frame screwed down to the brick chamber this morning
mixed up a bucket and mortared it down
one bucket wasn't enough so mixed a second big un and secured some of the loose stonework in front of it ..... was gonna do a bit more, but decided it was time for some lunch ... washing out me bucket and dropped me fag case in the water :mad: ...
got it out PBDQ before it'd shipped much H2O -- bigger issue was I keep all my PINs on a post it in there and had to come in and copy it all before it disappeared ... mission accomplished but was gone three by the time I dealt with that and'd eaten and CNBA to go do another hard fought bucket full
give what was there a chance to go off and go again
had an hour instead adjusting the brakes on the Lil' Tug and trying to find a belt number as it's slipping like buggery and really struggling .. amazingly I found one !!!
be here on the 7th apparently ... looks like it'll e fun to fit
William127
William127
Saw this one with optional machine gun at Operation Market Harborough last weekend 😆
Reminded me of a conversation I had with my mates slightly gullible wife when I got mine -
'What's that then?'
'A convertible tank' (It just popped into my head 😆 🤣)
'What's it for?'
'Summer time wars'
'Yes, but why do you have it?'
Lovely 👌
I need to sort mine out 😆 🤣
'net pic I'm afraid ... mine's not so shiny ... but it is completely original -- I'm the second owner
there's a story to it when I collected it .... pretty sure i have related it before - my first drive was a baptism of fire down a loooong 45 deg slope from the guy's house.
as you'll know they are seriously nose heavy so bought a 3 cwt anvil sat in the guys garden - ratchet strapped it to the implement lift on the back - picked it up and set off downwards ... figured it'd make a good anchor too if needed
After mixing a couple of buckets/trugs of mortar and consolidating some more of the stonework down the lawn I was cooked ... been 'kin warm here again today and gonna get hotter apparently .. I was nadgered, so got the Countax out to clear the lawn of all the weeds, that, aside from the prolific growth over the soakaway, are the only things growing ATM.
shifted Lil' jake out the way/off the grass and set to it ....
unbelievable quantity of dead leaves and a serious amount of dried grass/growth of some sort collected ..
and dropped on the side of the drive for barrowing down to my tip spot
then did the side of the drive with the 5 /6 passes I can keep the uphill back wheel on the floor for ... added significantly to the pile
put the mower away and fetched the barrow to shift it all ... 5 stuffed barrow-worth there
and it was time for tea ....
lawn certainly looks a bit better for having all the crud lifted
the green patch took some mowing - 3 passes with the deck at high, mid then low settings to get through it all
I'll never make a living at this tish, but the boss is happy so - result
more jointing / pointing to do, but the mixing is killing me :rolleyes:
belt arrived for the tug about 3-ish - now have a number for the next one - which'd probably be half the price next time
old one off ....easier than i expected it to be
well bollo-ed ...
and had taken a caning in one spot
wrestled some lumps onto the sack truck and got 'em down the lawn ...
then sorted some more for on top
second pallet is disappearing slowly .....
but not a lot of useful stuff appearing 'out if the rubble'
got some more mortar knocked up and set a few of the next stones - forgot the pic - I'll get one later
the 'soakaway' on the lawn is browning off rapidly after it had a hair cut and is a pretty visible square now
had a barrow load of roots, dry grass and general crud from down the lawn and already had a binful waiting - nice south westerly breeze this afters, so the bin had to have it @Stock :giggle::giggle:
went well too :giggle:
go down and brush off the stonework 'bout 9-ish and then get a pic or three ;) - should look better in the half light :ROFLMAO::ROFLMAO:
Jimoz
'What's that then?'
'What's it for?'
'Summer time wars'
Bollocks I usually go to that. Completely missed it this year? Do you go to the victory show? Ill be going on the Saturday this year weather depending.
William127
William127
It was a great show, really enjoyed it.
Haven't heard of the Victory show, looks like it's the same weekend as the land rover show at Belvoir Castle anyway. Diary is rammed these days 😆
I assume the belt doubles as the clutch?
I learnt a bit about belt construction when I was reco'ing my own. The construction of "mower belts" is very different compared to a regular V_belt.
Often (but not universally) the part number for a standard belt would "A-82" for your belt in a standard construction, but AK-82 for a mower belt (A is the section, K is Kevlar, numbers = length in inches or millimeters).
Your worn out belt clearly doesn't have the outer kevlar 'sock' needed when the 'belt is the clutch', but also, the standard construction does not survive the belt being folded back on it's self as happens with an idler on the top surface.
Mine's a bit longer than yours and was a complete PIA when I needed one in a hurry. No "K" in the part number, but it's shown as a 'mower' belt.
Mine's a bit longer than yours and was a complete PIA when I needed one in a hurry. No "K" in the part number, but it shown as a 'mower' belt.
correct ... this one was supposed to be a direct equivalent for the countax numbered belt fitted to the tug
TBH I did wonder how it copes with the 'slip' at the crank end, but I'll give this one a go ... can't be any worse than what came off :rolleyes::giggle:
I'll have a hunt about for a kevlar version now I have a length/size to go by ;)
thanks for the heads up :cool:(y)
I think the new one you have is correct - it has woven fabric down the side of the V?
The old one looks wrong as it's the conventional (layered) construction.
When I couldn't get the correct belt, I tried a conventional belt, it failed by de-laminating
