Funnily enough I haven’t seen many finance offers flying around this year, only CAT early on in the year, nothing much since?You and me both mate! Especially over five years finance....
Yes at full steering lock and full articulation the skip get pretty near the steering column the cab is square on the front so they wound the steering stops out to stop it colliding@T whiting interesting comment on steering lock - I hadn’t envisaged this being a thing? The Thwaites version literally looks like they have just stuck a cab on the mainframe?
Thwaites were 8k more for a cab with ac fyi @Gunners 🫣
Plenty of subsidised finance out there. But with base rate where it is it’s all more than folk are used to.Funnily enough I haven’t seen many finance offers flying around this year, only CAT early on in the year, nothing much since?
My e10 was 0% a few months ago, would of been rude not to.Plenty of subsidised finance out there. But with base rate where it is it’s all more than folk are used to.
It’s still the best micro by far if you are dealing with tight gaps.My e10 was 0% a few months ago, would have been rude not to.
Just not been shoved under my nose as much as it had been previously!Plenty of subsidised finance out there. But with base rate where it is it’s all more than folk are used to.
Its not the JCB 444 engine one you want, go a little earlier and get a Terex with the Deutz TCD3.6, those were proper rockets, around 90hp in the 6t and 110hp in the 9t! I did the majority of the installation development on that and the JCB one.And thats £8k on top of an already inflated price for the standard machine!
Had prices well north of £20k for a 3t straight tip earlier this year. When you can hire them for £130/week its just not worth owning one.
@T whiting has a good point here. Find a pre 2018 Terex with the full fat 444 engine in - before they nuked them to 75hp. And spend some money refurbing it. Even with the cost of the best raincoat you can buy for your operator - its going to be a better machine for half the cost.
Just let my old one go, 10 years old 2500hrs never had a pin or Bush in it. Don't get me wrong you could feel the freshness between them but I do keep on top of greasing and the odd shimmIt’s still the best micro by far if you are dealing with tight gaps.
Out on mine today, 7 years old and just ticked over 700 hours. £400 readies by 13:00 and 8 litres of diesel used, what’s not to like?View attachment 83650
how'd you get away with tipping that on the road .... would be all over you here with the first shovel fullIt’s still the best micro by far if you are dealing with tight gaps.
He legged ithow'd you get away with tipping that on the road .... would be all over you here with the first shovel full
Do it all the time.how'd you get away with tipping that on the road .... would be all over you here with the first shovel full
pretty sure it's what's in my Thwaites 6t swivel - JCB axles and boxesWe have two with 1004 phasers.
Was using this 1.5t thwaites the customer had on tyre. Not my cup of tea tbh- a 2 ton is only marginally wider but a far more solidly built machine. Thicker skip etc more power and stability. The 1.5t feels very garden-esque and It felt pretty tippy with even those modest rocks in itI agree, the 1 ton dumpers look and feel unstable, for the tight access i use a small tracked dumper - the skip is not that far off size wise and you get more control. Ability to move on gh104 trailer is essential - I'll keep an eye out for a 2.3T thwaites. There's a nice looking thwaites 1.5t swivel hi tip on fb market that's looks just the ticket. Timing is not good for me though - need to finish a few jobs before I can invest further.... back to the original question of this thread, I would not get a cabbed version. Extra weight, extra cost, extra stuff to break. I will get a fishing brolly and cable tie to rops!View attachment 83626
Yours looks quite different to this one I was using. This one is more like a slightly wider 1t high tip. All very Mickey mouse steel. Yours is a manual by the looks and seems more substantial designView attachment 83702
My thwaites 1.5t hi swivel is same as a 2t. Plenty man enough for the job and you get way more than 1.5t in the skip
Id agree although the beauty of the 2t is it's 1500mm wide so will go everywhere a 3t digger will go whereas the 3 ton dumpers tend to be more like 6ft wide. Less of an issue the bigger the kit all getsguy that i worked for always insisted that the digger and dumper should be the same size ie 3 ton digger 3 ton dumper 30 ton digger 30 ton dumper
always seemed to work out fine
Yes it's a manual, hydrostatic versions were available but very very rare to find.Yours looks quite different to this one I was using. This one is more like a slightly wider 1t high tip. All very Mickey mouse steel. Yours is a manual by the looks and seems more substantial design![]()
