Kinshofer tr 025
very interesting - hope the 30 deg.s will suffice and dare say you'll become used to it ... the ram set up on those is indeed VERY compact ... will be really interested to see the gripper design ... hope it serves you well and produces the same reliability Kins have built a reputation on - no doubting their stuff is top notch - but expensive - get what you pay for though (y):cool:
I've decided to go for it. TR025 has been ordered.
I've got direct mount, df06 t/e (6 pipe, tilt sharing with extra function), I've been given the opportunity to buy a, yet to be released, integrated gripper for it at a heavily discounted rate (£3k off anticipated rrp) in return for feedback, which I have gone for.
It's s30 - 180 lower coupler, and I've got 3 RF system buckets with it, a cable bucket, a digging bucket and grading bucket. They weren't cheap, but they're made from hb400 and hb500 for the cutting edge, they are light, and I figure the geometry is optimal.
Thought it was an interesting offering beyond the usual steelwrist/engcon/rototilt. I like the look of some of the other kinshofer products, it all looks like very high quality stuff, particularly the grabs - hopefully it'll be the case with the tilty.
Kinshofer UK HQ is just up the road from me in Cheltenham, and I've heard back up from Kinshofer is good.
All in the bill is £13.3k + VAT, due to be fitted late June. So far I can't fault the service from Kinshofer, they have been responsive and answered all my questions when I've asked them.
I do have concerns about 30° tilt, but in my line of work I think I can tolerate this limitation. I also accept that direct mount is a compromise, but with the lack of protruding cylinders I reason that it'll mitigate some of the drawbacks, I'll also save on weight, cost and build height.
With almost no user feedback, it's a gamble, I'll certainly keep everyone updated with my honest thoughts about the unit 😀
That seems a good price, but interested to see show it works out for you, I never got any prices when I was enquiring they only do direct mount so wouldn't quote, be interesting to see how the gripper pans out as no one else does one for that size
Maxus
It's arrived and getting installed!
Maxus
Yes gripper is removable by undoing two bolts, I don't think it's available to buy yet, I've been selected as a guinea pig, which I'm very happy about. The pipe work you see on top of the gripper is a work around so I can manually switch between gripper and any attachment i need to run... my understanding is the final product will have a better way to connect attachments.
Looking at the incredibly small size of the hoses running the gripper, I don’t think I will be running much in the way of attachments though- which is not a huge deal for me, the gripper will more than make up for that I hope - but we will see.
The engineer also seemed quite surprised by the size of the auxiliary pipes and connectors on the EZ26, to couple with the tilt rotator, pipe diameter will need to be reduced significantly. The EZ26 is definitely in the biggest category of machine for this particular unit, looking at it I wouldn't hesitate to put it on something smaller.
Grahams
Grahams
When I ran attachments under a tilt rotator not enough oil would go through the head so ran direct off the two way breaker circuit and only rotated 180 degrees either way. Worked fine after a bit of practice. I only pulled the pipes off once whilst not concentrating.
Maxus
Anyone got any ideas about where to put the switch to toggle between tilt and grab? Apparently the button on the joystick can't be used (encased in resin apparently).... they've put one on the control panel, meaning I'll have to take my hand off the joystick to activate... would a foot pedal be better?
Surely they can drill a hole in the joystick and fit another button.
Maxus
Yea we did this for @Thomas7740 on his EZ26
Good to know.... If I could get some basic advice on how to do it and proof that its possible, I'd have thought they'll have pull there finger out and get it done, i was pretty specific in saying it needed to be switchable while my hands are on the joystick! Even if it's a foot pedal....
can get Lucas, steel, floor mounted, momentary (for horn), or latching (for dip/dazzle) switches.
https://www.ebay.co.uk/itm/22701298...qveEZ9qKfZTc4r7a4Q4hJJZ2A=|tkp:Bk9SR_KNmpXjZw
