Next car ,parked on ones drive ,i suggest forks on the drema and put it in a tree
Especially using the druid spec forks!
I'll have to go back and look see what it came up with Jim, but what I ordered, I sourced from their online selection system, which didn't have an exact match, but was close enough, dimensionally, other than the body being 30mm too short, hence my extension pieces ... the stroke, body and rod diameter were perfect, as were the mounting studs for the mounts I re-usedDid you use the struts that the AI spiel reccomended in the end or did you research a pair?
It’s amazing how ‘open’ areas feel when you give encroaching vegetation a good hiding - you don’t notice it growing, but smashing it back hard to where it used to be makes such a difference!bit of a 'gardening' day ... nearly took my eye out a couple of times on the Dane, last time it was out ... one of our plum trees had a load of dead branches on the back of it, so they had to come off and a.n.other tree needed to lose some low hangers ...
next door's foliage has been over hanging a big area for a while so thought while I was at it, I'd give that a trim too .... can't get under it on the Dane anymore, so 'bout time .... was a lot more than I first appreciated and took me a while, but got there in the end .... 's gonna take some burning though
was gonna put the trailer behind the lil' converted Countax I set up last year for tushing trailers about, 'til I found the damned pulse fuel pump didn't want to play... could've gotten a lot closer to the piles with that, but got it loaded in the end
and mowing along here with the Dane's gonna be a lot less hazardous now
was about 15ft out over our ground, too low to get under anymore and 90% brambles growing in the trees .... vicious stuff to get down...... forgot a before pic, as hadn't planned to tackle it today
yeh - remarkable how much it had encroached TBH .... could do with the hedge trimmer on the pole going over it just to finish it off tidy (and the chainsaw for a couple of limbs still protruding on the hawthorn ... amazed how many 'battle scars' on my arms this morning and still picking out bramble thorns from the backs of my handsIt’s amazing how ‘open’ areas feel when you give encroaching vegetation a good hiding - you don’t notice it growing, but smashing it back hard to where it used to be makes such a difference!
I keep a chunky Niobium (rare earth) magnet handy for such times - drop a screw or clip and it'll still pick it up even if it's slightly buried.I lost it- and failed to find the damned thing
I've got a magnetic wand and a 28" magnetic 'broom', on wheels .... went all over the whole area .... picked up a lot of crud up, but no link -- I will inevitably find it at some future point, but just not yesterdayI keep a chunky Niobium (rare earth) magnet handy for such times - drop a screw or clip and it'll still pick it up even if it's slightly buried.
that's a heinous waste of a good straight tipping skipYou need a bigger fire pit![]()
Very much NOT a good skip. Bought 3 good uns last year and this one thrown in for £50. Pretty much corroded detached all way round the bottom between the sides and base and not even tippable. Dare say with enough time and plate it could have been made sound but far more use as it isthat's a heinous waste of a good straight tipping skip![]()
Haha!unbearable last night - was 27C here at midnight.
Sod that, I normally have my best sleeps when I wake to a notice on my phone - 'low temperature, slow charging'Haha!
I have the AC set to 28C in the bedroom - all year.
