Plant trailer choices.
Is that 14ft? Looks shorter.. kinda wish I'd gone for a beavertail but didn't want to go longer than 12ft for my needs
Yes. It would sometimes be nicer to have a 16ft, but it does everything I need. Beavertail suits me with the various things I move, but can be a pain if you’ve got something long and flat as obviously the beavertail angles away. I was told the newer beaver tails have less of an angle which defeats the object of them but don’t know how true it is?
My Bateson turned up today. Main use is for towing the dumper so went with Tri axle because find it noddy on the dual ifor. Unusual to have a Tri at 12ft but the way i see it for the extra 100kg your getting another braked axle so never going to overload your axles and on these pot hole infested roads it just glides, and strapping points and ramps are also lovely compared to the old LM, really well put together👌
Tri axle trailers just look so much nicer 🥰
Are you sure a 14ft wouldn't have been better ? 😂😂
You’ll be able to tow the dumper fully loaded with that - I reckon it’s probably good for 12 tonnes gross!
Still think a mesh hinged ramp better, I hate pissing about with separate ramps. BTW - how long are those ramps? Look more like 10ft than 8ft? Its a lovely looking trailer. Hope you are happy with it.
Yeah a one piece ramp would always be easier than individuals, but drop down ramps aren't always perfect either especially if loading on undulating ground. They're 8ft ramps but so much easier to pull out then the ifor. This one has a leaver that pulls a gas strutted dampener down on to the ramp to stop them sliding out and stops them rattling- can't hear a pip squeak behind you with this trailer! Also like the fact that the axles are all galvanised too.
I put the old 8ft steel ramps back in under my new trailer recently. It really made it MUCH louder. Then I put the drop sides on. You can hear me coming now :-(
Do you need the propstands?
Anyone heard of these!? Looks quite a good design and liking the 2945kg payload. Although that is without a bucket rest- that wouldn't bother me tbh
Not very good lashing points though
something not right here???
