S B Rural Contracting
What's the e27 like without the extra counterweight? I was half thinking of leaving that off and putting steel tracks on.
Ah. I recognise that post knocker. Were you on arbtalk asking about it when you were building it? What size hammer weight does it have?You lot have inspired me, seeing as its a nice day and all. I get it now, somewhere to rest your feet View attachment 81487
And chained the post cap to the bottom of the mast- a man who hath seen the light!You lot have inspired me, seeing as its a nice day and all. I get it now, somewhere to rest your feet View attachment 81487
Yeah they're all much of a muchness by the time all the bits have been added to make like easier. Tbh I like a stripped down flatbed as much as anything because theyre pretty light, flexible with different machines. a bateson 12x6 is 600kg without ramps so perhaps 650 with and gives a bit more room for either attachments or load positioning them a standard plant trailer- the down side is its more of a faff dealing with ramps and props standsI bought the bateson trailer because it was marketed as light, I think it was something like 580kg. I added a strip of ply to the centre of the trailer and with a spare wheel it was mid to high 600's but can't remember. Split ramps have meant I can't move a roller which is really annoying, otherwise they're great
It's the shorter skids that get the most payload but it's not a huge difference over the longer skids. There's something like 4 different rear options on the gh1054. Would have thought you could still get a roller on with skids they do have sideways adjustment it's just the retaining bolt that holds them in place when driving is crapI bought the bateson trailer because it was marketed as light, I think it was something like 580kg. I added a strip of ply to the centre of the trailer and with a spare wheel it was mid to high 600's but can't remember. Split ramps have meant I can't move a roller which is really annoying, otherwise they're great
Yeah that was me. The lump was 160kg and then by the time I welded on brackets etc for it to slide I think its probably about 170-175kg. I tried to keep the rest of it light but thinking about it it's probably a bit more than 250kg in total.Ah. I recognise that post knocker. Were you on arbtalk asking about it when you were building it? What size hammer weight does it have?
Hadn't ever really considered a flat bed but it makes sense. Yeah the prop stands are a pain.Yeah they're all much of a muchness by the time all the bits have been added to make like easier. Tbh I like a stripped down flatbed as much as anything because theyre pretty light, flexible with different machines. a bateson 12x6 is 600kg without ramps so perhaps 650 with and gives a bit more room for either attachments or load positioning them a standard plant trailer- the down side is its more of a faff dealing with ramps and props stands
The bateson has a steel backing for the number plate, between the skids, that sits about an inch higher than the bed of the trailerIt's the shorter skids that get the most payload but it's not a huge difference over the longer skids. There's something like 4 different rear options on the gh1054. Would have thought you could still get a roller on with skids they do have sideways adjustment it's just the retaining bolt that holds them in place when driving is crap
of less portly proportionsI see Yanmar have update their SV26 now. They have improved the offset boom to the left which is good- slightly odd looking machine at the rear and to me looks like quite a small cab/door entry but could be a good option for those wanting conventional tail and legal towing- the offset on the old machine was always what put me off them
Indeed- must be aimed at the Asian market! and also smaller engine and less reach than the outgoing model.of less portly proportions![]()
Smaller engine is never good.Indeed- must be aimed at the Asian market! and also smaller engine and less reach than the outgoing model.
I think they flow share pretty well for attachments/grabs etc. Don't think theres too much negativity on them on here it's just the restricted offset, agricultural and somewhat noisy cabs when I had one on hire but otherwise decent machinesSv26 seems to have a decent arb following?
Surprised at feedback on here though
It reminds me of a fiat multipla!It’s an ugly duckling for sure.
Wonder how it drives?
No air con option either.I don't think it looks too bad, from a design point it must increase visibility around the machine, lots of cheap looking rocker switches in it though.
Still has 2nd aux as an option that's the one thing that the Chinese counterparts get right
