Wouldn't be stupidly expensive i wouldn't think?
A plant hire guy about a mile from me has 1, just had it resprayed a year or so ago. Think it's around 15 years old said best van he's had.
Brought the Avant back today along with a load of stuff on the truck they pull like a train
It’s been chatted about on forum before . The trailer Is the dear bit as needs to be aluminium to make the most of the situation, and the electric braking not cheap. I’d love to see it done. You’d need a hook lift really so you can run a mini set up like @Furniss :) but on a B+E license with no Operators license / tacho etc.
Clip rails are my friend!
We use clip rail in a crucifix pattern (if a square room) then concentric MLCP at 150mm centres and clip with gun.
You will get a more consistent floor temp with concentric , once you start using thermal cameras for looking at systems you can really see the difference.
Need to be an old fart though....
The E19 clicked over 1000 hours yesterday. The E27 did the same on Wednesday.
The E19 is 2021, the E27 2024. Just shows how little I use the smaller machine.
Everyone has b+e now. But only pre 95 can use that exemption for a gooseneck.
I am post 97 licence, did my B+E in 2008. Wasn't aware that the goosneck part had a 1995 date on it? I will need to take a look at it if I win the lottery!
I did mine that year too. So we are on the uncapped version as in we can tow over 3.5t, obviously the vehicle/combination has to be able to.
I think the max of 3.5t on the b+e came in 2013 or 2017 without looking it up.
William127
William127
12 pallets of blocks shifted in the Slanetrac today, through the gate, up the steps, up a soil ramp and then up a ramp of crushed for 100 blocks and 1 ton of sand.
All done and away by 2, including an hour on the digger 👍
Simon edwards
Simon edwards
Had to take up a load of grassmat that didn’t work with grass (surprise!), relay with shingle .Plus ongoing handling work with the 3cx, been very handy ticking about for months with the current fuel cost😉
