Had my eye on this for months- 6kva perkins engined genny. Came with an enclosure that I'm pretty sure would have been made by the guy I put enclosures in for, but at least 30 years ago so a bit before my time!
Been up for a while at a grand, dropped to 600 this week so I offered him 4, we met in the middle
Bit smaller than I want but I can't justify thousands just so I don't have to run an extension lead over the road every so often
Only 40 minutes away, took a winch and chains but had it on a couple of dollies and we pushed it straight up.
Got it home and had it running out of a can in about 20 minutes. Came with an oil filter so we did an oil change. There's no hours meter on it but if it's done more than 100 I'd be amazed
Old filter was like new and a genuine perkins. Air and fuel filters were spotless.
Seems to be all working, makes power, gauges work, glow plugs work, warning light works, charge alternator works.
Wrapped up the leads and fuel lines and started modifying the canopy. Originally fitted in a corner so it's just 2 sides and a roof, I rummaged through the scrap pile and found a couple of suitable panels
Did 90% of the end panel, but ran out of cutting discs, and it was getting a bit late on a Sunday so called it a day
