Has anyone here had experience welding a trunnion mount onto a hydraulic cylinder?
I’m planning on sourcing the cylinder itself from Steerforth in kit form and then welding it together. One issue I’ve run into is that the inlet/outlet port on the cylinder barrel is already welded in place which complicates trunnion placement.
To mount the trunnion, I’m currently considering two options:
- Machine a U-shaped relief in the trunnion to provide clearance for the hydraulic port
- Manufacture the trunnion in two halves, position it around the cylinder, and then weld the halves together once in place
I’m unsure whether either of these approaches is best practice, or if there’s a better way of doing it without risking distortion
Any advice, alternative ideas, or examples of this would be very welcome.
View attachment 78710View attachment 78711
