W
How are you finding the power and ergonomics compared to the MS170?Seems to be cutting ok![]()
Feels good, lots of power as well.How are you finding the power and ergonomics compared to the MS170?
click on my ID below to go see what I useThat will do for today, one lot cut ready for splitting, and no, I shan’t be using an axe.![]()
IIRC was £850 delivered from Ireland -- fella called Shane McCarney on FB makes 'em
My Husqvarna just uses the D shaped tool (Walbro carb) which I bought from my local dealer, but worth checking first because I think they also may use a star shaped key.Carb adj on the husky seems to require a special tool, anyone know the correct item to buy.
That looks like it![]()
Husqvarna Carburettor Adjustment Screwdriver - OEM No. 597 10 85-01
Overview: The Husqvarna Carburettor Adjustment Screwdriver (OEM No. 597 10 85-01) is a genuine service tool for precise tuning of Husqvarna carburettors on petrol-powered equipment. Built with a hardened steel shaft and awww.lsengineers.co.uk
my 135 uses a splined tool 21 splines i think l and s engineers will know whats needed.Carb adj on the husky seems to require a special tool, anyone know the correct item to buy.
Sounds about right - might be that your Stihl wasn’t oiling correctly. Always fill the bar oil when filling the fuel.Long time since last posting regarding this.
Suitable tool purchased and adjustments made.
I’ve noticed that the husky uses a lot more chain/ bar oil than the sthil, approximately one tank of oil per tank of fuel.
Is that what others have found?
Mine is like thatLong time since last posting regarding this.
070 107cc. The smaller brother to the 090 the largest production saw built and the younger brother to the Stihl Contra the first production one man saw built. That one was bought new by my grandfather in 1968 got another aswell they was used on a double ended bar for milling. Can happily run a 5 footer slow but the torque is mega. Its a duanting task to start it even with the decompressor it takes some pulling them and the 051 are the only ones I have to start on the floor.What saw is that? It looks like an 08s on steroids.
Pretty much I got a TS350 super I imagine alot of lads on here remember those old donkeys which is essentially an 08s with a large air filter and different cutting attachment. We did have an 08s until brother nearly cut his head off (dont ask) and sold it at auction still covered in bloodOh - so it is an 08s on steroids![]()
