1st job of the day was a s**t 1.
Both manhole backfalling did tell her last time we were there!
Was going to pour this after shuttering around 2.30 this afternoon but it would have gone quicker than I could mix i rekon. So early start tomorrow View attachment 73226
been 30C here most of the day and 'sposed to be hotter tomorrow - could be a VERY early start :oops:
William127
William127
Loaded up ready to be on site at 6 in the morning, try and beat the sun πŸ₯΅
Beauty of the 1.7- digger, buckets, mixer, cement, water etc plus however many kg of ballast make the trailer exactly full πŸ˜‰all on the one trip. Only got about 20 minutes digging to do then a couple of hours building.
Actually carried the sleepers into the woods by hand yesterday! 20 minutes effort saved a whole extra run with a trailer tomorrowπŸ‘
Little Bridge to build over a ditch, hopefully done by 12 then away for the weekend 🀞🀞
Took the 35 instead of the truck when I had a site meeting there on Monday 🌞
how does the Hodna engine on the mixer respond to a nap on its side?? :unsure::oops:
William127
William127
better get it out then :p:giggle:-- good idea - have the power source distant from the mixer(y)
It's out, ready to go- diggings done but I'm going to give it till 7 before I start the genny/mixer πŸ˜†
Early start and stripped already. Don't have to be perfect as will be slabbed or tiled.
Another day NOT being a heating engineer and instead messing about on the farm. Very slowly making this small corner of Devon more level.
Just realised that my BILs 1996 NH/Ford is the most modern tractor I’ve ever driven πŸ˜‚
And it was Pasty Friday :)
That pasty looks good!
bobthebuilder
Has anyone got a failsafe way of getting a cat cable thru a 25mm water pipe ,50 meters ish no joints .downhill already buried
Ta muchly
My Ninja finally gave up, been great tbf used a couple of times every day for a few years. Range cooker oven been broken but hob still works.
Didn't want to buy a cooker as when I get to the extension build it'll all be ripped out so bought a Ninja oven
