Took a trailer full of demo waste from mine back to the yard and we’ve a new addition it seems, plus don’t look to closely at the genie lift with the digger counter balance lol 😂
Only way of getting it in heavy bit of c section
Druid probably work it out was meant to be 180 x 90 x 26 PFC but local place had a 200x90x 15mm bottom sections and 8mm back it was bloody heavy the proper one should have been 96kg this was easily double that at 3.7m long
there is only one weight of PFC per size .. 180/90 is 26.1kg/m and the 200/90 is 29.7 kg/m so not a lot in it @Giles - more Weetabix required for the extra 13kgs :ROFLMAO::ROFLMAO:
Like watching paint dry
So long as I know in advance that I’ll be watching paint dry (and also getting paid machine rate for it), I don’t have a problem with it.
my eldest cat in work used to ride around on the rear bonnet of the H80C Hyster 4 t FLT (nice and warm) - would spend half the day on there curled up, no matter who was driving - got some pix somewhere, but can't find 'em ATM
Walls insulated. Forgot how much dust that saw saves along with a pretty square cut most of the time and way faster than a handsaw
Awesome innit? Best bit is how neat you can get the cuts with rail and then just snug them in👌🏻
I've not had any luck with the rail i find if the insulation is slightly bowed the track doesn't sit also the vibration moves the rail.
Any tips with the rail?
Did think about putting a packer under each end so you can push down on the middle
