Got a photo of sorts of repaired cover. Rest of it still sat in bits on the floor. Steam clean and oil change then put the roll cage back on. Be good to get some floor space back.Well today the repaired fan cover (courtesy of Charles) came back, and the unit was rebuilt with the new injector and the rocker seals (also courtesy of Charles) Still a little white smoke till she warms up, then the usual black smoke! Oil stays the same on the dipstick without ever adding it... so if its getting past the rings its not much? I will give her a good clean out while top is off and then an oil change. When I was in the WN place getting bits I got well over excited and bought some 2 pack paint for the thing. Didnt pay attention to the ££ which was a mistake! I might get around to painting it... or may wait till I have finished the top yard and the middle yard and the bottom yard and then dads yard and the back yard, and the works yard, I may find it no longer required and let it go to a new owner. That is at least 2 years away thoughWill try and get a photo tomorrow.
Charles had to remove washers from the inside and use dome heads as it was touching fan. Bolted not welded as very thin and galvanized originally? so wasn't welding well (and as its Charles I believe him!)
