Exactly 6 per meter, so I hope so. If life goes to plan it will be part of the view from my accommodation when I retire in another couple of decades. The hedge in the background of the photo is one my dad planted back in the 80s, but not enough time or money to build a bank for it so it always struggled on the poor wet ground. It got a ditch about 12 years ago and has improved since then.That’s going to be thick old hedge![]()
Impressive load. That would deffo be a vosa magnet up here!Chatter about this on the Auction Watch thread at the weekend. Popped down to pick this up tonight. I had a job to measure up for a friend which was about half way . Took longer to strap it than it did to load it . Fitted like a glove. Boards were loose so lay them down on trailer bed. Too heavy for Fassi to lift clean at that angle as I woud have needed the extensions out which wouldn’t have been nice, so laid it down and dragged it on. Took the long way home round the dual carriageway and playing tag team with HVGs all way back. Dropped trailer at the farm as that’s a tomorrow problem. Forklift lights have failed so unloading is a daylight job.
£350 feels like a bargain . Might get the Vat off that as well.
Dmax is a very capable towing trug, but I prefer driving a van .
Couple of hi vis tabards pallet wrapped to the legs for good measure.
Noticed that one of my trailer side running lights has died…. Need to sort that.
PerfickChatter about this on the Auction Watch thread at the weekend. Popped down to pick this up tonight. I had a job to measure up for a friend which was about half way . Took longer to strap it than it did to load it . Fitted like a glove. Boards were loose so lay them down on trailer bed. Too heavy for Fassi to lift clean at that angle as I woud have needed the extensions out which wouldn’t have been nice, so laid it down and dragged it on. Took the long way home round the dual carriageway and playing tag team with HVGs all way back. Dropped trailer at the farm as that’s a tomorrow problem. Forklift lights have failed so unloading is a daylight job.
It was dark when I drove back for a reasonImpressive load. That would deffo be a vosa magnet up here!
Tank stand . Hopefully will be using it for a 5000-10000 litre rain water tank once the shed gets cladding and gutters. I fancy a volume washer one day. Used to have one on the farm and it was the mutts .What is it??
Your centre of gravity is waaay out thereFairly heavy. Fancy it might be more than 800kg!?
Got crane trailer unloaded and back home ready for lifting some boilers out of a plant room tomorrow (actual work stuff) it’s much nicer pulling behind 3300kg of fwd Transit than behind Dmax …. Until you get to a hill or rough ground or want to go backwards
Once jack legs down to get it up and then pulled in close then it's okay. Would want to be going backwards down hill though.Your centre of gravity is waaay out there
Sling it centrally and get some height I bet it would lift it![]()
if the U/bs're 203 x 133 then I'm pretty close based on the advertised dimensions.Fairly heavy. Fancy it might be more than 800kg!?
Yeah just the COG being 1200mm away from heel of forks is all it takes to make a huge difference. Moffet is a good lifter in close. Always surprising how much extra lift capacity you get with stab legs down, but must only move the tipping point 300mm forward.if the U/bs're 203 x 133 then I'm pretty close based on the advertised dimensions.
if it's made out of 254 x 146 it won't be much more TBH
Will do.Keep an eye on auction sites, they go for next to nothing!
