Steve
Or someone forgetting to turn the tap back on
I’ve never done that …. HonestOr someone forgetting to turn the tap back on![]()
gravity feed the pump from a 2litre coke bottle attached to its inlet ... if it primes, lights and burns .... the issue is elsewhere in the line (like filters/unions)If none of the other piping has been disturbed, I'd be checking both ends of the clear pipe in case it's cracked inside the ferrul and drawing air.
As a sanity check, is it worth filling the plastic pipe from the NRV end so you can see the pump drawing it through?
airlock in the feed pipe ?I eventually used my car brake bleeder on it. View attachment 67120
Not sureairlock in the feed pipe ?
the filter will block more with water than shite Dyl ... a water saturated filter will not flow kero .... have had it beforeI cleaned the filter at the tank and cleaned the fire valve thing at the boiler.
The filter was a bit shity but not bad.
I thinking my problem or 1 of the problems is shity fuel. The fuel coming through the clear pipe into boiler has small particles in it. Think there's an issue you can get with heating oil, a bio organism.
So I after advise again
Thanks for everyone's help
The kero is flowing but perhaps not as it should. I should be able to get a pipe into bottom of tank to pump the water out if there is any.the filter will block more with water than shite Dyl ... a water saturated filter will not flow kero .... have had it before
any water in the tank will settle at the bottom .. outlet end of the tank should be higher than t'other end, which should have a drain bung in to remove the water, which accumulates at the lowest point
Tanks are installed level for the last 30 odd years , although a single skin steel with a drain at low end is a very practical idea , just sadly breaches building regs!the filter will block more with water than shite Dyl ... a water saturated filter will not flow kero .... have had it before
They do , but expensive and only take up small amounts of water.You can get water absorbing filters that you drop into the tank in a cord. No idea if they actually work?
Would you replace the fire valve (is this a one way valve)
Job.
Clean water out of tank if there is any.
Put in line paper filter next to boiler.
Blow feed pipe out with clean fuel.
Where's best place to order from, be a job for weekend.
Thanks all
you'd be very lucky to retain a perfect 'column' in the pipe as it's withdrawn though Dylan -- I'd be more inclined to suck off the bottom and see what you getBe sorting this out on Saturday hopefully.
To see if there's any water in the bottom of tank. I'm thinking before I get the pump in there could I just put a bit of clear pipe to the bottom and put my finger over the top bit of pipe. Is this to simple, what am I missing
