Boiler problems
diggerjones
diggerjones
I've got a combi oil boiler. It's been playing up so tonight I changed the nozle. Now I can't get rid of the air. The tank is half full. The boiler needs to suck it up about a metre. Never had this problem before. Any bright ideas
presumably you disconnected the supply line from the pump ?? ... is there no bleed port on the pump? is your tank line connection drawing air ?
diggerjones
diggerjones
Yes I disconnected pump to put new nozzle on and clean electrodes. I've been bleeding it from the bleeding screw. There's a continuous stream of air coming. There's a length of clear pipe before it enters the pump where you see the air. I'm stumped
On our boiler it is a pain to bleed at the bleed screw. Have to do it at the injector.
diggerjones
diggerjones
It's like it's getting air in, but can't be or oil would be escaping. It was OK before I took the pipe off
Obvious question but did you isolate any valves? Tried old nozzle back in it?
the pump will only suck fluid if it has fluid in it .. if it's dry it has no chance... can you fill the pump and maybe your clear length of hose from the bleed port with a few syringe-fulls of kero?
What boiler do you have? Clear tube makes it sound like it might be an HRM or a Grandee wall hung affair? 🥴
If tank below burner then it must either have a tigerloop/deareator or a non return valve on the line.
Start at the beginning. Check tank filter clean and free of water. Check any other external filters ditto. Check the Firevalve hasnt tripped. Suck oil through to flexi using a suction pump to ensure clean air free supply. If you have changed the nozzle you need to be checking combustion readings once it fires which means a flue gas analyser.
We use these to pull Kero through. Have adapted them with some lathed bungs that take BSP fittings so we have a vacuum gauge and iso valve on them.
diggerjones
diggerjones
fuel has probably run back down supply line and emptied pump when nozzle line, etc., disconnected
The pump is working. Its pulling fuel up, but with a load of air. Think these boilers have a built-in none return valve.
