Yes saw that but already have an s45 top/bottom engcon with my name on it, and a steekwrist s45 hitch for the machine on a pallet ready.
The reason I want it under a top hitch is so I can use a breaker and also use a proper grab with the hitch pins angled. Tiltrotators are very limited for full time grab work.Gripper !
Just saying 🫣
Macleans're 'proper' ppl to deal with too![]()
STEELWRIST X12 Tilt Rotator Hitch (ST21142)
STEELWRIST X12 Tilt Rotator Hitch (ST21142) 45mm Pins 4 Pipes £7,500 +VATwww.tractorsandplant.com
So.... you like the gripperI know im like a stuck record about grippers , but you like time saving efficient kit @doobin and gripper is right up there !
ive just dismantled a retaining wall that had leant over (turns out builder had piped topwater from the back of house roof and patio behind it 5 years ago and it finally did for it !!) but anyhow I only had one place to sit in front of the wall and lifted sleepers out of rsj's with gripper and stacked them , spun bucket round and reduced backfil as I went then repeat till it was down, when it went back up it went the same way, even placed and held rsj's with gripper
Honestly the best 3k I've EVER spent.
If I was buying new I would probably spec a detachable one.Saves me no end of time and effort - think you need to have had one for a while to really get how useful they are though which makes them a harder sell I suppose.
Wish I had as much shoestring !If I was buying new I would probably spec a detachable one.
Secondhand on a shoestring- I'll take what I can get!
You don't know how much shoestring I have! Probably less than you think. Hence I'll take what I can get!Wish I had as much shoestring !
Make your own!? Im sure someone on here might be able to offer assistanceYou don't know how much shoestring I have! Probably less than you think. Hence I'll take what I can get!
I’d of gone for a gripper if they were detachable when I had mine from new…If I was buying new I would probably spec a detachable one.
Weight and price was the factor for me not having 1. More the formaI’d of gone for a gripper if they were detachable when I had mine from new…
Can’t justify new prices for the little work my machine does these days!
I'm guessing on the towable machines they simply add too much weight and bulk to be feasible? Something that puts me off engcons is that I don't think they'd work well with a thumb- which is a real shame.Weight and price was the factor for me not having 1. More the forma
I think on mine would be 40 ish kgI'm guessing on the towable machines they simply add too much weight and bulk to be feasible? Something that puts me off engcons is that I don't think they'd work well with a thumb- which is a real shame.
something I've fancied having a bash at, to attach to my VA-r .. but never seen one in the metal, so not quite gotten my head around some of the design aspects - plenty of pix, but always summat you can't quite see/make out/etc. !!Make your own!? Im sure someone on here might be able to offer assistance![]()
I wanted weight saving too! I can’t help but fill every bucket to the brim, which can make tilty machines abit noddy! Extra 40kg++ would make it even worse!Weight and price was the factor for me not having 1. More the forma
And 40kg right out far too.I think on mine would be 40 ish kg
From what I have seen they don't do grippers for the s30 size, so it's S40 and the additional weight of the tilt unit unit and then having to run larger/heavier buckets.I'm guessing on the towable machines they simply add too much weight and bulk to be feasible? Something that puts me off engcons is that I don't think they'd work well with a thumb- which is a real shame.
