I’m surprised you have that 8 tonner on rubbers for your work.
Mind you, having had a quote to change mine over, maybe not so surprising!!
It's a hired machine. Tb290 has terribly weak tracking. £2800 I was quoted to get my own 8 tonner on 600 steels- what were you quoted?
William127
William127
Giant loading up bits to take to auction 👍👍 quad was about on the limit 😆
A fk site more than that!! I think around 8k from astrak who are normally cheap.
Wait, just checked. That was a quote with both width options 🤦‍♂️ £2300 per side (600mm) which includes a different srive sprocket.
Who quoted you? Mine is still nearly double the price.
il call you tomorrow, you will be happy:)
MST tracks. This was last year but sure it was £1400 a track for 600mm
Yup just checked £1425 per side for 600s
Conor
Conor
Breaking piles down a big hole 🙃 there's two pc400 komatsus and 2 Piling rigs down there too.... pc850 long reach in background for scale. It's a hard climb up and down the scaffold stairs 🤣
Decided to be an alloy wheel thief today. 🤪
Drilled center then opened it up with 4 more and it popped off.
Yes, there's proper tools to remove them but I don't possess them.
Yes, a garage/tyre place could of done it but all tyres are rotten aswell as the valve stems.
View attachment 65887 Drilled center then opened it up with 4 more and it popped off.
couldn't you just drive an old socket onto it ?
No, just not enough room to get a socket on over the outer, it was only protruding a couple of mm and the small inner ring was just too thin to take it.
I did try it on the rear one yesterday but drilling was the fastest and less chance of damage
Jeez that's a big hole
A s**t job but someone has to do it
